Results 1 to 8 of 8
    Veteran Member Four Rings VAG_4ever's Avatar
    May 27 2008
    IL
    Forge SPLT-R Question...
    I just recently put in the Forge SPLT-R and my vacuum has changed.. I am still hitting boost normally, but in vacuum where as it used to read @ 20, it now reads @ 15.. Was wondering if this was normal since the splt-r is in the hybrid mode or if its just a vacuum leak somewhere..
    Thanks in advance..
    -Meredith
    Saint Cloud, Fl
    Re: Forge SPLT-R Question...
    Vacuum leak somewhere, I was always at 19 -20 when I was running mine. Make sure all of the clamps are tight. Also did you replace the old vacuum lines with new ones ?
    instagram ------------> low_enforcement
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Check the hose for splits. The valve itself won't affect your vacuum unless it has an internal leak, i.e. bad o-ring or diaphram.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    May 27 2008
    IL
    alright thank you guys, ill check it out
    Senior Member Three Rings FourRingsB6's Avatar
    Oct 07 2008
    2005 A4(HIS), 1999 Jetta(HERS)
    Lancaster, PA
    Mine holds the same as the stock. Did you have a dv on there before? If so, maybe try to cap it and take the splitter to dv or stealth mode. This should act the same as what you had before. If you still have the problems then it is probably a loose fitting or leak somewhere instead of something having to do with the valve itself.
    Stretched, poked, and slammed.
    May 27 2008
    IL
    yea i had the 007, i will do that, thank you
    Veteran Member Four Rings BNZ TOY's Avatar
    Oct 29 2006
    1G FX35, 03 R6, B6 A4 MT6
    Vancouver
    So, what happend? Did you find a leak or was it the Split-r?
    (amber forever, but likes the whooosh, eh? )
    Another silver B6
    Go/Stop: K04-015 ~ Intake/TIP ~ Forge Splitter ~ Neuspeed turboback ~ B&M SS ~ H&R Sport w Bilsteins ~ S4 Sways ~ Eurocode FMIC ~ 245 Rotors/18z ~ FX300 240mm LWFW ~ Snow Meth Inj ~ EURODYNE tune
    Flair: USP Front ~ Cupra R ~ S4 Trunklip ~ Euro Roof Lip ~ VMR v710 235/19/35 ~ S4 doorblades ~ B7 rear valance ~ LED fogs ~ B7 DTM skirts ~ Euro RS4 Steering Wheel ~ S4 Recaros
    Veteran Member Four Rings got boost.'s Avatar
    Jun 03 2007
    california
    Quote Originally Posted by BNZ TOY View Post
    chicks dig the whoosh. They can care less for clear corners.
    l BBS l FORGE l STERN l VMR l ER l SPEEDTUNE l
