Results 1 to 11 of 11
    Veteran Member Three Rings drexplode's Avatar
    Jul 19 2007
    2016 M3 - maximum hooligan
    Michigan
    smell of burning and possibly white smoke...
    I've had my new to me B5 S4 for a few weeks now; purchased from 1997GTX (Adam). We are still waiting for the title to show up in the time the being the battery has been a little bia*** due to lack of attention and cold weather. Every few days I jump start her and take a few trips around the block and then IDLE for 10+ mins to recharge the battery (hopefully).
    Afterwards I pop the hood and check for the green indicator light on the battery. Everytime I have done this I can smell something burning and white smoke moderately coming from the left side of the engine. I dont see any leaks and oil volume is ok.
    Any thoughts, or is this normal for the 2.7TT?
    Thanks guys.
    -Greg
    PS: i love the car, and hope to keep her for years to come. Before i get banned, here are a few pics pre-delivery:
    "A turbo boost gauge the size of a fat spaniels face! - Jeremy Clarkson
    Veteran Member Three Rings o3spec's Avatar
    Feb 07 2007
    Dover, DE
    Re: smell of burning and possibly white smoke...
    is it a sweet smell? sounds like a very small coolant leak
    edit- its not uncommon
    Jul 19 2007
    Michigan
    Quote Originally Posted by o3spec View Post
    hmm does smell kinda sweet. Once i get plates, she has to visit my audi doctor for a routine check up so i will have him take a look at it.
    probably a coolant thing...
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    could be a vc gasket also
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Feb 07 2007
    Dover, DE
    Quote Originally Posted by s42k5b View Post
    wouldn't be white smoke, and most people know what oil smells like
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    It's leftover oil burning away from the Valve Cover job (left VC gasket) and oil change.
    I don't think it would be coolant. Dealership did a replacement and relocation of the after-run pump. If for some reason it is that, check the coolant level and make sure it's okay. Worst case scenario is if there is a problem, dealership should replace since they did the job the first time -- warranty covers that as well.
    Wait until you drive it for a good distance and check the burning then. It likely just needs the spillage / seal to be perfect on the VC. Car has been driven less than 20miles by me since both those jobs were done.
    Text me ... I can tell you everything about the car =)
    --Adam
    Have questions? E-mail me.
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    its the turbos :) jk
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Jul 19 2007
    Michigan
    update: valve tensior seal was leaking slightly, in process of being fixed at my local audi doctor!
    May 31 2008
    New York
    every bad vc gasket ive seen smelled like burning rubber...
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    Alot of modern synthetic oils burn white...including Mobil1 and Redline. There are many others that will burn an extremely light blue, but appear white when its really cold outside. Also, there are coolants out nowadays that burn more of a blueish-gray and smell nothing like youre average sweet smelling coolant. Those old school tricks are harder to apply to todays oils and coolants.
    OP-Sorry for the thread jack, and good luck on getting it fixed. Also, i wish i has access to the previous owner of my car like you do. Thats an invaluable perk that comes with buying from another enthusiast!
    2000 Brilliant Black S4
    -DNA Catback, Piggies, Darintake w/ITG panel filter, 710n's, 034 TBB, 034 F hose, Vast clutch, JHM shifter & bushings, Vogtland/Koni's, Hotchkis Sways, ECS 12.5mm spacers
    2010 Honda Civic Ex Sport Auto
    -Stock daily driver/panty dropper
    2014 Fiat 500 Sport
    -Stock cone dodger for now. Suspension coming soon.
    Jul 19 2007
    Michigan
    Quote Originally Posted by sCeRaXn View Post
    To be honest it was a few months ago that I posted this thread i cant remember what the smell is; however, my local mechanic (german motor werks) is makin her all better. Stefan is the man
    Adam is a great guy, and took care of this car extremely well. You should see the list of things that have already been fixed, also there is a warranty left over for another 8k/1.2yrs. Actually, im thinkin about sellin to move on to something else...we'll see The turbos pull hard and make no noise!
    FYI... here is the list of stuff that has been done (in case of future sale):
    mods
    stage 2clutch @ 53k miles
    light weight fly wheel @ 53k miles
    APR93 octane chip @ 53k miles (60% driven in stock / 40% driven in 93 mode)
    Samco Throttle body boots @ 53k miles
    Forge 007 diverter valves @ 53k miles
    RS4 motor mounts @ 71k miles
    APR snub mount @ 87k miles
    Custom wired sirius satellite radio (currently no service)
    Harmon Kardon IPOD adaptor
    Nexus Boost gauge
    H&R springs
    M3 Lip Spoiler
    custom front license plate
    maintenance
    oil change w/ 5W30 Mobil 1 every 4k miles
    upper control arms @ 75k miles
    lower control arms @ 92k miles
    All O2 sensors : 1 @ 53k miles, 1 @ 71k miles
    Coolant temp sensor @ 53k miles
    EGT Sensors @ 53k miles
    tranmission fluid flush @ 53k miles
    brake fluid change @ 53k miles
    Spark plugs @ 87k miles
    Aux water pump (and relocation) @ 78kmiles
    Valve chain tensioner @ 87k miles
    timing belt @ 87k miles
    water pump @ 87k miles
    Valve cover gaskets @ 92k miles
    Cam Tensioner Seal @ 93k miles
    New battery @ 93k miles
    Brand new 225/45-17 Kuhmo ecsta ASX ultra-high performance all-season tires
    anti-seize applied to all 4 corners
    new wheel bolts available just in-case
