Results 1 to 40 of 56
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    S4 + snow + understeer =
    In 3rd gear (notice it touches shift trim )
    4th gear (looks like neutral and feels like a short shift)
    just quick pictures. fender is dented in,motor sits against radiator (fans broke because the motor clipped all the blades off)
    Veteran Member Four Rings belinko's Avatar
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    Re: S4 + snow + oversteer =
    ouch!
    if in doubt always apply throttle when slipping
    1.8L, JE pistions, IE rods, APR stg3+, GT28 Turbo, Setrab, ER comp. FMIC, APR HFC, Milltek Cat-back, APR 91, 93, 100 - CM FX 300, CM 240 LWFL, JHM 4:1, AMS SS, RS4 Motor Mounts - 355mm Alcon 4 pot, 300mm Alcon S4 - Stasis/Ohlins MS, Hotchkis Front and Rear, Stern adj. CA Front, 034 adj. CA Rear - 18x8.5" Work CR Kai wheels, NT-01 & Dunlop Z1 star spec - RS4 Front bumper and grill, Tow Strap, RS4 E-codes - SPA Technique Dual Digital gauges Oil & Water temp, Oil & Boost pressure, RS4 Door Handles
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    Aww man, just a little too much fun. What did you hit? Cracking a rim is not easy on our cars. Hopefully you just screwed up all your mounts and no major damage happened. When I started to take apart my car, and I saw the passenger motor mount, sheared off the frame, I had my doubt. Good luck man, and keep us posted
    Nov 13 2007
    B5 S4 Avant
    Boston
    wheel is actually bent under the car and doesnt turn,doesnt show in the picture.
    and yes,i was ken block driving all night,this was bound to happen. and when slipping and adding more throttle and trying to pull the ebrake,it just didnt work out 1 time out of 200 last night.
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    Wow that really sucks!
    Good luck getting her fixed up..
    Usually the answer to your equation is "fun".
    Brilliant Black 2001 S4 - 6MT <3
    Veteran Member Three Rings road race s4's Avatar
    Jan 03 2009
    camry
    Ouch, how fast were you going?
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    for your shifter, open up the surround and check the bolts, they probably moved forward. second, check the control arms and tie rods. if its as bad as u say i hope u didnt break the rack. i did that when i hit my mustang
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Nov 13 2007
    B5 S4 Avant
    Boston
    Quote Originally Posted by road race s4 View Post
    35-40mph. quattro can usually handle it...not this time.
    yea insurance adjuster comes monday, sucks i just put on a $1k deductible. we'll see what happens. gonna be a good amount of damage,probably not totalled but because the engine is so far forward and broke fans,etc i dont know.
    Veteran Member Three Rings ToMMyRsK04's Avatar
    Dec 26 2006
    2000 audi s4
    New York
    Quote Originally Posted by EuroSteez View Post
    loll "ken block"
    bye bye AWE Stg 3+ and HeLLooOo ........
    For Sale
    - VAST Port & Polished Intake Manifold - BEST OFFER
    - Stock B5 S4Pistons/Rods/Valves/Springs/Retainers/Cams 44k on them
    - Two GT3076 Turbos
    Veteran Member Four Rings Videlov's Avatar
    Jul 01 2008
    Chicago, IL, Bulgaria
    Ouch, what'd you hit?
    "Some Redbull, some water, some nice fresh house music!"
    2000 Audi S4 (Sold)
    2010 Audi S4 (Next)
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    that sucks, driving in the snow is fun, but damn there are too many s4's ending up badly injured.
    B5 S4 AWE Stage 3 - sold
    Nov 13 2007
    B5 S4 Avant
    Boston
    Quote Originally Posted by Videlov View Post
    granite curb
    Jul 06 2005
    Re: S4 + snow + understeer =
    I bet these would have been cheaper than your deductable.
    I think you total'd her.
    Slow, stock, smurfy blue car.
    Relax, I just troll this place for fun.
    Oct 30 2006
    B8 A4 Avant 6spd
    Quote Originally Posted by Shomegrown View Post
    Not even remotely. Few bent control arms and offset tranny linkage is def not totaled.
    -18 718 GTS
    Jul 06 2005
    Quote Originally Posted by Militant-Grunt View Post
    Depends. If his shifter only slipped, you're probably right.
    If his shifter is messed up and engine is sitting on the fan because everything shifted...he's fucked.
    Nov 23 2007
    Columbus, OH
    and some people say snow tires aren't necessary
    Senior Member Three Rings jblinga's Avatar
    Jul 24 2008
    '01.5 S4, '96 Maxima
    Mor_onville U.S.A.
    What tires are you running?
    '01.5 S4 6MT 2+
    '96 Maxima (DD)
    Nov 13 2007
    B5 S4 Avant
    Boston
    things needing to be replaced that i can see:
    bumper and lower grills + paint (just got this one,and it was upwards of $2k from Audi)
    fender and both fender liners + paint
    drivers side wheel and tire
    timing cover,bipipes,radiator fan,fmic (if covered but prob not)
    drivers side headlight
    plus any mechanical issues like control arms,axle,trans and motor mounts,etc
    Nov 13 2007
    B5 S4 Avant
    Boston
    Quote Originally Posted by jblinga View Post
    michelin all seasons...never got around to throwing on the aplins that are sitting in my garage
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    That's nearly worth crying over. I'm sorry to see that. I hope all goes well repairing it.
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    I'd say that's borderline totalled - the engine / transmission must be shunted back a fair bit to get your shift to be in that position.
    If the drivetrain's moved due to busted mounts, then not too bad. But personally, I think you've got frame damage. Your propshaft and rear diff won't like the shock either.
    I must say, it takes a hell of an impact to do that much damage.
    Nov 13 2007
    B5 S4 Avant
    Boston
    6" tall granite curb at 40ish will do some damage...wish i coulda pulled out of it,but not this time.
    yeah i was thinking some frame issues,but not sure. have to get it up on a lift or something to take a peak at everything...
    wouldnt mind it being totalled,not gonna lie. rather get something new that doesnt have the issues a car thats been in an accident will ya know.
    Jan 29 2007
    08 S4 00 S4
    MD
    True..if that's all that's wrong with it..But his entire drivetrain is shifted if the shifter is situated how it is. Plus, the motor is into the radiator...He did some serious damage...Totaled would not be that surprising of an outcome.
    08 S4- Stock SOLD
    Veteran Member Four Rings CruzS4's Avatar
    Mar 01 2007
    WK2
    Conshohocken/Sea Isle
    OP i hope everything works out for the best. with the age of these cars the likelihood of a total is much higher which blows. i gotta give you props though for admitting that you got a little too gutsy in the snow and lost it, unlike all the "a cat ran out in front of me" or some shit threads
    '17 Ibis White B9 A4 quattro P+ S-Line
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    damn that's shitty!
    wasn't your car rs6's w/ built motor or something? or was that someone else?
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Veteran Member Three Rings rouellettea4's Avatar
    Apr 07 2005
    00S4STG3, 1995 Subaru Impreza, 96 A6 (blown HG)
    Holden/Worcester, MA
    Quote Originally Posted by belinko View Post
    ouch!
    I remember yelling that from the back seat while drunk couple hours before this happened!
    Sorry this happened kyle, hope it works out.
    Senior Member Two Rings nocturnals4's Avatar
    Dec 10 2007
    '00 S4, '94 Z28
    P-dena,Maryland
    pay to play
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Dude, that sucks. I can think of a few better ways to start a new year.
    Nov 13 2007
    B5 S4 Avant
    Boston
    Quote Originally Posted by sean1.8t View Post
    damn that's shitty!
    nope,stage 2+
    Apr 07 2005
    nope,stage 2+
    I thought you had GTs??
    Veteran Member Four Rings 2001A6's Avatar
    Sep 17 2008
    Stuff
    St. Charles, MO.
    Dang, that sucks man. I hit a low curb sliding this year, the lot was strait ice. Neither quattro, snow/ice tires, ABS, e brake, power, nothing could stop it. Lucky me though, it was like 2 mph, scraped the right front winter rim, o well. And even if I bent something, it gets new suspension all around come March :D My friend did worse damage to his cobalt, bumper, hood, fender, wheel, front sus, headlight fell out, caused all his lights to go out, dash and all, engines in power reduction mode too. ECM is in that corner. Sucks, but happens to the best of us... Good luck with everything!
    ~Matt.
    - PES Supercharged 01 A6 2.8Q
    -01 A6 4.2
    -04 Touareg 4.2
    -89 951
    - 99 Viggen
    -06 GTI
    -04 W8 wagon
    -01.5 S4
    The C5 Union
    Veteran Member Four Rings amd is the best's Avatar
    Oct 05 2007
    '91 200 20v, 01 A4 2.8 PES
    Manteca, CA
    Nokian Hakkapelitta FTW!
    2012 Golf TDI
    2001 A4 2.8 Avant
    1991 200 20v
    YouTube
    8V Audi S3/RS3 Facebook Group
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    damn that's a bummer, i have been having bad dreams lately about stuff like that happening to me this winter. when i drive on snowpacked roads i always have people riding my ass, but i seriously want to be as careful as possible.. it's temping to have fun but i never risk it
    this is why, when i see people on the b5 forums (and there are a ton) saying "yeaah brah i was out driftin on the streets today in the snow"
    i think, goddamn what a fucking dumbass. nothing personal.
    {99.5 Avant}
    Nov 13 2007
    B5 S4 Avant
    Boston
    i keep my fun to WIDE open parking lots. i admit, i was playing around, wont deny it. but it wasnt "DJ Skeet Skit snow day '06 mother******s" ( http://www.youtube.com/watch?v=jIeC9ghOQPo ) haha.
    and i wasnt this idiot; http://www.youtube.com/watch?v=US6R4...next=1&index=1
    haha but yes, i was playing.
    Sep 17 2008
    Stuff
    St. Charles, MO.
    LMAO at the first one. Shitty sliding too. Second vid looked like fun, but hes not to bright casue he broke it. I had fun, but also only in large empty lots. Wasnt playing when I scuffed the curb, leaving the lot driving slow after playing! Some luck...
    ~Matt.
    -01 A6 4.2
    -04 Touareg 4.2
    -89 951
    - 99 Viggen
    -06 GTI
    -04 W8 wagon
    -01.5 S4
    The C5 Union
    Jul 01 2008
    LOLOLOL I had seen the first video last year and I've been looking for it since then hahaha, read the comments, they are fucking hilarious.
    SNOW DAY 06!
    2000 Audi S4 (Sold)
    2010 Audi S4 (Next)
    Apr 07 2005
    Quote Originally Posted by Jibberific View Post
    Your from Arizona, I can't see you understanding. Part of the fun of having an Audi in New England is going driving around in the shittiest weather possible haha.
    Veteran Member Four Rings J Ozzie's Avatar
    Jun 06 2008
    Port Moody, Canada
    Ice is shit! ive been lucky so far with ice... been able to pull out of it most times.. Pretty much ive just instead of hitting the brakes, id just let go of the petal and try to stear out of it.... ending in a drive away
    2014 Audi Q5 TDI - Brilliant Black | LED Fogs | VCDS Mods | LED Interior swap |
    R.I.P... (wrecked)2005 Audi A4 1.8TQM 6Speed
    R.I.P..2001 Audi a4 1.8TQM (casa white no sunroof)
    Vancouver Audi Club.ca
    where's our resident intoxicated lobster Canadian - Thomas
    Veteran Member Three Rings Ianxcom's Avatar
    Jul 30 2008
    Socal/Denver
    What tires are these?
    Nov 13 2007
    B5 S4 Avant
    Boston
    looks like a dunlop logo...winter sports probably
