Results 1 to 22 of 22
    Established Member Two Rings sloweryucf's Avatar
    Feb 21 2008
    2003 A4 1.8T (sport package)
    Orlando, FL
    idle drop when a/c is off?
    Idle drops to 800 rpm and it's rough. What the hell is that about?
    GO KNIGHTS!
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    Re: idle drop when a/c is off?
    when you turn the AC on the computer compensates by raising the engine RPM because the AC puts a load on the engine. so when you turn your AC off its prolly adjusting and drops back down.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    With a combination of possible bad motor mounts.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Mar 31 2004
    CA
    Quote Originally Posted by dirtybrd View Post
    ahah true. that could be that "rough" feelin hes getting
    Mar 21 2006
    Lakeland, FL.
    You should caught right on to that Audi tech.
    I'm back bitches!
    Mar 31 2004
    CA
    smart ass... i actually just read it reeal quick and saw that he asked about rpms droping.... dint catch the rough at first
    hey how is your car running BTW? any #'s or anyhting?
    Mar 21 2006
    Lakeland, FL.
    Runs great, no #'s. I haven't driven it since mid Oct. I think the gas has gone bad in it.
    I'm back bitches!
    Mar 31 2004
    CA
    ahah.. why havnt you driven it?
    im hoping by end of the month my car will be done. I ended up changing the setup that im doing.
    Mar 21 2006
    Lakeland, FL.
    I drive my Honda everyday, 130 miles a day and 35mpg. I leave the house at 5:30am and get home around 7pm. Between spending time with my lil girl and taking care of things around the house on the weekends, I just haven't had the time.
    I'm back bitches!
    Mar 31 2004
    CA
    damn. sounds like my life right now. minus the drive to work. thank god i work 1 mile away from where i live.
    anywho sorry for the thread jack.
    Mar 21 2006
    Lakeland, FL.
    That how it used to be. I can almost see my old job from the house. But there I wasn't bringing home $1200 a week
    I'm back bitches!
    Feb 21 2008
    Orlando, FL
    Brand new motor mounts unfortunately. I thought it was that as well.
    GO KNIGHTS!
    Mar 21 2006
    Lakeland, FL.
    Misadjusted snub?
    I'm back bitches!
    Mar 31 2004
    CA
    Quote Originally Posted by sloweryucf View Post
    is it a shake or like a rough idle because the RPMs drop low and come back up ?
    Feb 21 2008
    Orlando, FL
    Misadjusted snub?
    They (dealership) did put a new OEM snub mount in. Perhaps I should try and recenter it. Thing is that I don't remember the RPM fluctuation on the dash.
    GO KNIGHTS!
    Feb 21 2008
    Orlando, FL
    Quote Originally Posted by Audi Skate Snow View Post
    Not a shake, rough idle. The RPMs drop and stay down when the a/c is off. When the a/c is on, sometimes the RPMs drop and then come back up.
    I also thought there might be a vaccum leak but dealership said no leaks. Not sure how the a/c system works with the engine to be honest with you.
    GO KNIGHTS!
    Mar 31 2004
    CA
    ok so are your RPMS droping really low when you turn it off
    Aug 26 2005
    The idle speed differential that you noticed, is due to the programming of the ECU. My '03 used to do this also, until the ECU was reflashed to the '04 "AK" suffix software version. The "AK" software has this idle speed offset corrected, and it does not occur now. Your ECU can be updated with the "AK" version by the dealer.
    Veteran Member Three Rings pa4ul's Avatar
    Mar 20 2008
    03 Audi A4 1.8T/ 72 Ford F-100
    south
    my car does the same thing. When the AC is on the car dosent studdered but once the ac goes of it seems like it has alot of trouble stayin on. It has even turned off on me before. Is there an idle adjustment maybe>? help.
    Joooe Mamma!
    Feb 21 2008
    Orlando, FL
    How much does that run?
    GO KNIGHTS!
    Aug 26 2005
    The ECU software reprogramming to PN suffix "AK" version will eliminate the idle speed difference with the A/C ON and OFF. Another way is to use VAG-COM/VCDS to adjust the idle speed in ECU adaptation channel 001. However, the idle adaptation channel is directly adjustable only for ECU versions up to "AF". For ECUs after "AF", IE "AK" >, the adaptation channels are locked against direct change, so Lemmiwinks or similar is needed to access the idle speed adaptation channel, but since the idle speed offset with A/C mode is not an issue for versions "AK">, the adaptation channel lock out isn't really an issue anyway.
    Aug 26 2005
    Dunno, probably the minimum shop labor time, at least. The software update is documented in the TSBs, specifically to address a cold start misfire problem. The reflash update is the '04 "AK" ECU PN suffix after the reprogramming is performed.
    The TSB says to perform the update only with the customer's complaints of cold start misfire, for warranty. If a paid job, then jusk asking to have the update flashed should be the only requirment.
