Results 1 to 33 of 33
    Dec 05 2006
    So. Cal.
    Official: Newbies with used car issues.
    I decided to make a thread to post all the issues that the newbies are having with their used car purchase. Seeing as the S4's are coming down in price, there are a lot of people that have snatched up used S4's and RS4's for that matter and become official One-Ringers. However it seems like these used cars are not without their little gremlins.
    Lets try and leave this thread for the problems that they are having and not the solution as their thread will provide them the answer. This thread is only to see how many problems used S4's have.
    p.s. make sure that they are One-Ringers.
    I'll start:
    Quote Originally Posted by sjporzio View Post
    the red lights indicating the buttons are getting power are lit on the map lights above the rear seat. However, when I push in either of the buttons to turn the lights they dont work. Does anyone know how to remove the unit to change the bulbs, and/or know what fuse controls that unit to check that as well?
    thanks
    Veteran Member Three Rings SebringSilver's Avatar
    Oct 04 2006
    TT RS
    Vancouver, Canada
    Re: Newbies with used car issues.
    Great idea, Ed.
    Currently Driving: '18 TT RS | '18 Velar P380 HSE First Edition
    Gone and Missed: '18 TTS | '14 991 C4S | '11 R8 V10 | '09 R8 V8 | '09 C63 AMG | '06 B7 S4 | '94 NSX | '92 NSX
    Dec 05 2006
    So. Cal.
    Re: Official: Newbies with used car issues.
    Quote Originally Posted by Funkychriscoldm View Post
    Does the check engine light come on if I need a oil change??
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by johnjsb View Post
    Well I have had the car for about 2 weeks now and loving it. So like a dumb ass on thur i try to wash the top of the motor off (carefully), there was alot of sand and dirt like the previous owner was in the desert(yes i checked carfax). So on Saturday i drive to wendy's sitting at the drive through when i felt a strange rumble. I then leave and it felt like the motor was coming unglued like the piston was coming out of the block. At this point i was thinking F@%$ this can't be happening, I limp home at about idle the whole way only about a 1/20 of a mile. Before i bought the car i did alot of research here and other places so i knew there was no way i'm taking it to the stealership which is about a 1.5 hour drive from here. So in preperation i bought air filter, carbon cabin filter, oil, oil filter, plugs(iridium), vag-com, bentley manual dvd, guided fault light, anti freeze, power stearing fluid, and extra belt. I had a coil pack on that list as well and decided I wouldn't need it, guess which part failed here let me show you the log.
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 8E0 910 560 H HW: 8E0 907 560
    Component: 4.2L V8/5V G 0010
    2 Faults Found
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 001 - Upper Limit Exceeded
    16686 - Shareware Version. To Decode all DTCs (Cyl 2 misfire)
    P0302 - 001 - Please Register/Activate
    Readiness: 0000 0000
    So since it was my plan to change plugs anyway I did so, and swapped cyl 2 pack with cyl 5 (much
    easier to get to later). here is what i got.
    Address 01: Engine
    Control Module Part Number: 8E0 910 560 H
    Component and/or Version: 4.2L V8/5V G 0010
    Software Coding: 0007771
    Work Shop Code: WSC 08091
    2 Faults Found
    P0300 - 001 - Upper Limit Exceeded - MIL ON
    16689 - Cylinder 5: Misfire Detected
    P0305 - 001 - Upper Limit Exceeded - MIL ON
    Readiness: 0110 1101
    Saturday,27,December,2008,17:51:53:21461
    Address 09: Cent. Elect.
    Control Module Part Number: 8E0 907 279 F
    Software Coding:
    Work Shop Code:
    1 Fault Found
    02104 - Light Detection Sensor (G399)
    29-10 - Short to Ground - Intermittent
    Now what the hell could this be, could it cause other problems?
    What does "Redir Fail!" mean?
    Could my washing the top of the motor off caused this incredibly delicate coil pack to fail?
    I ordered 3 coil packs from different sources in hopes i won't be without for long.
    How far can you drive in limp mode before damage?
    After seeing so many coil pack failures I would think that audi would pull there head out of there asses and fix these things. Looks like a good aftermarket upgrade item, how many people would buy one that mimicked everything this one does but also acts like a multiple spark discharge system.
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    freakin' one-ringers :)
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
    Oct 11 2008
    Quote Originally Posted by channad View Post
    You talkin' to me?
    Oct 18 2007
    Moscow
    I'll start:
    Great idea. I would suggest throwing up the link to the thread in question for easy reference in case someone actually wants to know the solution.
    Dec 05 2006
    So. Cal.
    Yea, that's a good idea.
    Freakin' one ringers is right Channa. Everyone's gotta get hazed in.
    Quote Originally Posted by serumk View Post
    Hello, everyone!
    I'm the proud new owner of a 2004 S4 = )
    The car is absolutely pristine, and drives wonderfully, but I wanted to ask if anyone has ever encountered a situation where the clutch makes some sort of rattle/clanking noise for roughly the first two engagements on cold start. The noise is fairly quiet, but is audible, and can be felt in the pedal. The clutch does not slip.
    I assume it's the original clutch after 48,000 miles, so it's probably on the way out, but I wanted to find out if anyone else has experienced this.
    Thanks, and happy motoring!
    K. Andrew Serum
    http://www.audizine.com/forum/showthread.php?t=254923
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    You guys are mean... . Although I hate it when one ringers just come in here to explain their problems, get an answer, and never come back to AZ.
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    Veteran Member Four Rings boravr6's Avatar
    Aug 14 2008
    09 CTS-V
    Ontario
    can we sticky this?
    ** Proud to support **
    JHMotorsports
    AUDI Revolution
    ~ 2009 Blue Diamond Tricoat CTS-V
    ~ 2006 TD1 Imola B7 S4 sedan 6MT *SOLD*
    ~ 2004 Silver B6 S4 sedan 6MT *SOLD*
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    If we are going to go out of our way to post every noob problem in a single thread, could we try and post the solution at the same time?
    2013 White 911 4S
    Gone but not forgotten:
    2015 Sepang Blue S3 - 1 of 5 exclusive edition
    2004 Nogaro Blue S4 Avant w/ Noggy interior
    2005 Moro Blue S4
    Veteran Member Four Rings Fade2Black's Avatar
    Nov 27 2008
    Black B6 S4
    Springfield NJ
    WTF is search
    Veteran Member Three Rings Audi05s4's Avatar
    Oct 17 2006
    Hockessin, DE
    this will be a fun thread
    daworldisyours.com/forum<----check it out!!!!
    Veteran Member Three Rings GameBreaker's Avatar
    Mar 19 2008
    Phantom Black S6, GONE but Not forgotten: Dolphin Grey B6 S4
    Chicago
    I'm happy I bought CarFax way back when. It also helps that I'm the second owner and the previous one did every maintenance and only drove 7k miles a year!
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by ieatfishburitos View Post
    IEFB, we're gonna post the link to the thread also so one can see the solution.
    Veteran Member Four Rings serumk's Avatar
    Dec 31 2008
    2002 A4 quattro
    Kansas City
    I don't know if the clutch noise I have even qualifies as a "used car issue." However, the problems with the intake vacuum leak and MAFS definitely did. = )
    Veteran Member Four Rings B6bomber's Avatar
    Jan 05 2009
    05 B6 S4; 98 Nissan Altima
    LA area, Back in Simi
    I just bought my 2005 B6 S4 and I love it so far, but the damn drivers window just started clicking and I have to fix the o-ring problem with both headlights. Oh well, from what I read, working on your audi is just part of the love of ownership. Hey at least its worth it. I will be posting some pics later. Its stock right now, so I think its time to put some work in. Let me know what you guys think the first mods should be. Heres to many a post and countless hours on this forum...
    Established Member Two Rings MacTiki's Avatar
    May 01 2008
    Imola 04 S4
    Sacramento Area
    I will add one to this thread.
    04 S4 6MT reverse lights are stuck on, searched and no one else has seemed to have this issue.
    I did have my clutch replaced recently at 42k by 2Bennet in Cali, I asked them if it could at all be related and they said no. I didn't notice this before my clutch was replaced, could there be a correlation?
    Thanks in advance,
    Tiki
    Nov 19 2008
    San Jose, CA
    I have an issue with my used B6 S4 purchase. The car depreciated so much in the three years before I bought it that I have an extra $25-30K left over in my wallet.
    I'm thinking of buying a second one with the money I saved so that I will never be without transportation because of any "used car issues."
    Edit: Fogging headlights, clogged slush screen, rear pads worn (48K miles)--all fixed
    Dec 05 2006
    So. Cal.
    lol, now get out of here two ringer.
    Aug 11 2008
    DG Audi S4 Cab 2006 (B6)
    San Diego, CA, USA
    2006 B6 S4 Cab, 30k miles.
    Power Windows stopped working properly (left rear not fully retracted and some kind of synch issues when using the master up causing front right to go down again).
    Pads worn out (put on slotted/dimpled with HPS pads instead).
    Gear changer trim (CF) got loose on the outer edges causing the trim to get a U shaped form. Solvable with some superglue but I messed up causing a crack in the clearcoat/resin so I had to sand it down and rebuild it. Turned out nicer than before and I learned something new so cant complain.
    /Q
    Veteran Member Three Rings fitzS4's Avatar
    Mar 17 2007
    audi s4 chevy 2500 HD
    new york
    your window is prolly the regulator is broken very common on our cars...
    Veteran Member Four Rings jdmnomore's Avatar
    Mar 13 2008
    Orlando
    04 b6 S4 40xxx miles, purchased at 29xxx for $28000.
    During this current winter my second winter with the car upon start up i would get two obnoxious sounds. One was a whistling kind of sound that still happens every now and then on colder days and it lasts 10 or so seconds after startup and then repeats each time i left off the throttle and the rpms drop under 2k or so.
    The second more serious sound is a whining noise almost like a belt and is consistent. (Sounds almost like a loud bee buzzing). I originally thought it was my serpentine belt but the sound seems to be coming from parallel to the driver side front wheel. It is my understanding that there are no belts in that region that the a/c condensor, power steering pump and other misc parts are there.
    Well long story short a warm day came along i start the car and no sound what so ever. So im guessing our cars are noisy during the winter b/c i never got any feedback on possible issues.
    Last edited by jdmnomore; 01-07-2009 at 11:12 AM. Reason: oops i guess im a three ringer.. lol
    Aug 11 2008
    San Diego, CA, USA
    Quote Originally Posted by fitzS4 View Post
    Yup, covered under warranty :)
    Dec 05 2006
    So. Cal.
    Sorry, I bringing this thread back.
    This one is by newbie member OZO101:
    Quote Originally Posted by ozo101 View Post
    check engine pops, and i started feeling poor performance in the low rps, plug the scaner and i get a p0021 code for advance cam timing, bank 1 cam position sensor, replace both sensors , but no diference and code comes back , now my mechanic , thinks the camshaft should be adjusted by dealer, can this be done with the computer or is it a mechanical process what do the experts think? help !!
    http://www.audizine.com/forum/showthread.php?t=263240
    Oct 11 2008
    lol a useful question for this thread. Will a 355mm BBK fit in the 15 spoke 18" Audi Titanium Wheels [Here is a picture: http://www.wheelcollision.com/wccpix/58800grey.JPG]? I know that the stock rotor size is 345mm. Just want to make sure. If width is a problem too. I do have 12mm spacers up front.
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by Samster View Post
    Who makes the brake kit? I've seen aftermarket brakes on the ultrasport wheels, which these are.
    Oct 11 2008
    Stasis Alcon Monobloc4. Right now Im just thinking about it. Not really set on buying them yet.
    Oct 11 2008
    Anyone know?
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    I'm setting up a wiki...I've found it to be more useful that sifting through 400 pages of forum talk.
    Mar 09 2005
    Santa Clara, CA
    wiki is up at:
    http://audi.brainfl.com/
    I will be adding posts slowly
    Mar 09 2005
    Santa Clara, CA
    wiki is up at:
    May 27 2007
    13 S6, 05 S4 Cabrio, 05 A6 3.2, 03 4Runner
    Kansas City
    I have had mine for 2 years now, 2004 (Oct 06 build I think), had 23k mi when I bought it, I now have 47k miand I have had the following issues:
    Drivers side front Window regulator toast, solution was extended warranty replace it, at about 44k mi.
    Passenger side muffler rusted through, Audi factory warranty replace the muffler... was like that when I got it.
    Pretty much it, other than that only have needed normal maint, but I am getting close to 50k... where I have heard I need to put aside some cash for maint :).
