Results 1 to 11 of 11
    Veteran Member Three Rings ziggituning's Avatar
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    question for the K04 TIP owners....
    Ok my wife has a 03 B6 Q tip, I just did the T belt, so while I was at it I decided to fix a bunch of rattling and rubbing from the Intercooler and secondary air pump, etc (all installed before I got the car), the car had major vibrations before, now it is much better, BUT, I still feel alot of vibrations when the car is in D, in P or N it is pretty smoothe, but in any drive gear it seems to shake as if the mounts were not good.
    I looked at the 2 frt Hydr. mounts and they showed no signs of leaking etc. I put in a poly snub mount, but the car shook before that, so what else could it be.
    Mods are:
    K04
    GIAC
    380cc inj
    borla exhaust
    poly snub
    ER intercooler
    forge 007
    apr tip
    Any you TIP trans guys had this issue, BTW idle is holding at 900 rpm, the car does not want to die, just shakes alot.
    Thanks
    PARTS FOR SALE: LW Crank Pulley, OEM injectors, ABT rep grill, OEM Intercooler, PM me.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM![/SIZE]
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    Re: question for the K04 TIP owners....
    anyone?
    Dec 25 2004
    Earth
    The front snub mount needs to be adjusted properly, and or the transmissions mounts...
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    Quote Originally Posted by MikTip View Post
    I am pretty sure the snub is well adjusted, I find it fits a little snug, but I am ok at idle in P, only in D does it still shake, what about the trans mount? I know the trans is forcing forward in D but could the trsn mount be dead and that is why the whole car shakes? it really is only noticeable when stopped in gear.
    There is no real jerking or any noise just alot of vibration throu the car.
    Nov 28 2006
    2005 Audi A4, Yamaha gp800 Watercraft
    CT, USA
    you could check the transmission mount, but this shake at idle seems somewhat normal from what i have experienced...and in park you feel no vibes because the tranny is disengaged...
    Veteran Member Four Rings Smiley's Avatar
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Your wife has a badass car!
    Veteran Member Four Rings Turbo1A4's Avatar
    Aug 04 2008
    2002 s4 nogaro
    Jax
    mine does the same thing but all my mounts are stock
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    Quote Originally Posted by GtiRSmiley View Post
    Thanks, I just wish it was as smoothe as mine, I hate auto trans, but she did not want a man trans so...
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    Quote Originally Posted by Turbo1A4 View Post
    all the mounts except the snub are stock, I wonder if there is anything to be done to reduce the vibrations in D, are there any aftermarket parts out there?
    Mar 27 2005
    The Cold North
    which snub mount? some are known to produce more vibration that others.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    Quote Originally Posted by EBG 18T View Post
    I have the ecs one on both cars. on the tip there is vibration, on the man 6 sp ther is none. same mount.
