Results 1 to 7 of 7
    Mar 20 2004
    90' 964, 95' F355, 63' Coupe DeVille
    GV, CO
    RS4 clutch in S4?
    In my B5 I ran the OEM RS4 setup and it held up quite well to stg 3 power on pump gas. Is this a similar upgrade path for the B7? Or ??
    Veteran Member Three Rings ZachPDX's Avatar
    Jun 09 2008
    PDX
    Re: RS4 clutch in S4?
    Im not sure why but im 99% sure it wont work, someone please correct me if im wrong.
    05
    JHM SM/LW Flywheel + Stg3 clutch | JHM Piggy's | Milltek nonres | JHM Tune | JHM 4:1 Center Diff | Neuspeed 25mm Rear Sway | APR snub | Apikol Rear Diff | JHM SSTS | Vogtland GT's
    SomeGuyInAChair - "I'll be honest about why I signed up for a car forum without thorough knowledge of cars. I merely did a Google search with the following key words: "milf cougar forum advice help tips"
    Veteran Member Three Rings cam's Avatar
    Oct 11 2007
    NYC / west palm / las Vegas
    southbend
    Veteran Member Three Rings fitzS4's Avatar
    Mar 17 2007
    audi s4 chevy 2500 HD
    new york
    yea wont work try southbend..
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    echo... southbend....
    Bolt pattern is different on the rs4 or something like that, wont work.
    2013 White 911 4S
    Gone but not forgotten:
    2015 Sepang Blue S3 - 1 of 5 exclusive edition
    2004 Nogaro Blue S4 Avant w/ Noggy interior
    2005 Moro Blue S4
    Oct 11 2007
    crank is supposedly different on the rs4, leading me to believe the bolt pattern on the crank being different
    Stage 2 Banner Advertiser Four Rings jaybquick@JHM's Avatar
    Aug 24 2005
    Lathrop, CA
    I already did the research through the oem parts diagrams. Here is what we found.
    We did this research to begin the process of hopefully eventually putting together our own LWFW setup and clutch kit.
    PRESSURE PLATE
    The B7 S4 and the B7 RS4 share the same pressure plate (same part number, so the clamp load is identical). The B6 S4 has a different part number for their pressure plate.
    CLUTCH DISC
    The B6 S4, B7 S4 and B7 RS4 all have different part numbers for the clutch disc. (thickness, material, ??? haven't sat down and measured or inspected any new parts first hand) All 3 are 240mm.
    FLYWHEEL
    The RS4 has a 10 bolt flywheel(to the crank) thus is totally different. The B6 and B7 S4 both have a 8 bolt flywheel(to the crank) but different part numbers.
    THROWOUT BEARING
    All three share the same throwout bearing.
    From all this I am assuming that the B7 S4 has a better clutch than the B6 S4 being that the B7 RS4 shares the same pressure plate as the B7 S4.
    Hope this info helps.
    JHMotorsports AZ tuner spotlight VIDEO
    Check out our 11 and 10 second passes on YouTube
    B8 S5 4.2l - JHM Stage 1 SC Kit (ET: 11.8 @ 119mph) -- B6 S4 - JHM Stage 2 SC Kit (ET: 11.1 @ 128mph) – JHM Nitrous (ET: 12.29 @ 117mph) - JHM Bolt Ons -ALL MOTOR (ET: 12.70 @ 111mph) -- B5 S4 - JHM RS6-R (ET: 10.8 @ 130mph)
