Results 1 to 8 of 8
    Registered Member Two Rings
    Oct 06 2008
    2005 Audi A4 B6 1.8t 6sp
    engine noise when below 20 degrees
    Ok so when I start my car up and it is below 20 degrees the engine makes a really fast clicking sound that I have never heard before and I use to have a 1999 1.8t passat (now have 2005 1.8t A4). I can't figure out what it is but it goes away in idle after a minute or so, but then if i rev a little i can hear it again. I know these cars make some clicking normally but this is different and the normal clicking is still there. Also the clicking below 20 degrees is so fast it almost sounds like a solid note. After I let the car run for about ten minutes it goes away and seems to run fine.
    Just thought I would ask you guys before asking the Audi dealer to rob all my money.
    Thanks
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Re: engine noise when below 20 degrees
    Is the noise coming from the rear of the valve cover? The cam chain tensioner might be on the way out. Similar to this video?
    http://www.youtube.com/watch?v=VWlwK...eature=related
    Oct 06 2008
    i can't really tell where its coming from but that sound is similar. the only difference from the video is that my car idles and can drive. It didn't look like the one in the video could run. also mine is clicking very very fast.
    Just in case do you know about how much those cost to fix?
    thanks for your help
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Lifters.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Oct 06 2008
    lifters...... so is that noise ok or do i need to replace them or whats the deal.....
    Oct 06 2008
    ok so i just talked to the audi dealer and they said it was the secondary air pump kicking in to help the car run better when its cold. just thought i'd post this just in case anyone else was worried about this problem.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    What oil are you using? Brand and grade.
    I doubt the SAI is kicking in at -20F. Mine never did.
    20-32F.. sure. That sounds plausible. But -20? Nope. I think the dealer is full of shit.
    -Doug
    Oct 06 2008
    Mobil 1 OW-40 Fully Synthetic. I live in denver at a mile high, what do you think I should use? The audi dealer said its the secondary air pump but I'm not sure that I believe the audi dealer. It was doing it again yesterday and it was like 40 degrees out
