Results 1 to 14 of 14
    Senior Member Three Rings jrodpikap's Avatar
    Oct 23 2006
    2004 A4 USP 1.8T Stage 1 & 2000 A4 1.8T
    Conshohocken, PA
    F'ing Great News
    Driving down the highway today and the A4 starts to overheat and I get the Temperture warning light. So I pull over a few times and make my way to the nearest mechanic, not too far from my house (that's the good part). I thought it was going to be a thermostat or something small, because the coolant was full and pretty new.
    Get the call today and it looks like I need the following: Water Pump, Timing Belt, Radiator and Thermostat (I was part right)! Total = $1,400.00.
    That actually doesn't sound too bad for alll that labor, but I wasn't sure because all of the Water Pump experience i've had when one goes is that it literally breaks and leaks coolant all over the place. That didn't happen so I'm a little curious to know how they came to that determination.
    Anyway, I was just wondering if any of you have run into this before, do these symptoms sound right? Or could it be something simple like just a thermostat?
    Veteran Member Four Rings hoganalley's Avatar
    Feb 23 2007
    Burlington
    Re: F'ing Great News
    the only thing I can think of if the car kept running was perhaps the rad, thermostat and pump. It could very well be that the pump is seized and it's not flowing coolant, but you'd see damage done other places as well---maybe a stretched belt.....
    Other parts sound about right......
    05 allroad 2.7T Stock
    99.5 A4 1.8T K04 - Sold
    Oct 23 2006
    Conshohocken, PA
    Yeah, I haven't run into anything like this on my audi yet, so i'm not really sure, but it doesn't sound like it's too ridiculous, so I think I can give them the benefit of doubt.
    I'm in the process of finding the parts I need on ECS or somewhere so I can hopefully get the cost down a little.
    Quote Originally Posted by hoganalley View Post
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    dude i think hes lubin up right now to prepare for you. timing belt, water pump, and thermostat i could see you needing especially since thats part of the mile service but the radiator? radiators dont go bad unless they have a hole, as long as u flush it it would be fine. if you have any tools and an available weekend you can do the timing belt, water pump, and thermostat yourself for like 300 bucks or even less. i did all that plus the accessory belts in 6hrs my first time.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    it needs a water pump and timing belt only (along with tensioner, idler, and serp belts). unless its leaking, the radiator is fine. the thermostat is a fuckin cake walk to do. your mechanic most likely wants to cover all the bases and make sure everything is replaced, that way, its fixed for sure. im surprised he didnt throw in a heater core and coolant flange as well.
    our water pumps have a retarded ass plastic impeller, which is what breaks. it doesnt leak externally, and it doesnt "stretch the belt." the shit just breaks off the pulley and the pully free-wheels while the impeller just sits there not flowing coolant. this is why it overheats. when you replace it, make sure to get an aftermarket water pump (napa) as it has a metal impeller rather than the oem plastic catastro-fuck.
    my advice to you if you are mechanically inclined is to get the t-belt kit w/ water pump, as well as the thermostat, seal, and coolant, along with a 12-pack, and do it yourself. theres a few diy's floating around as well as the 5-min time lapse video which is pretty nifty. good luck bro and make sure to double check the timing!
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Oct 23 2006
    Conshohocken, PA
    Radiator is leaking at the seam, not that i've noticed, but that's the story.
    Quote Originally Posted by zrowcool View Post
    Feb 23 2007
    Burlington
    That's what I thought....I couldn't remember that impeller part.......
    but they are right. If you've never done it before, to do all that stuff is 8hrs max. I've done my own, and I will always do my own......
    Feb 27 2005
    North Wales, PA
    pm sent. I can swap all those parts for you. let me know
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by Poopie View Post
    yea man, save yourself the $500
    - Clint
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Get an OEM metal water pump impeller. See www.dieselgeek.com for the best options.
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by InTTruder View Post
    Pretty much all people that offer the kit offer it with the metal impeller. The ECS kit sucks though
    - Clint
    Oct 23 2006
    Conshohocken, PA
    Yeah, it was quoted with a Water Pump with a Metal impeller. I think the only place you can get a WP with a plastic impeller is the f'ing Audi plant.
    Apr 06 2008
    Brandon, FL
    Quote Originally Posted by jrodpikap View Post
    but trust me, the plastic impeller is a way better design. i mean just ask the engineers. they'll tell you....
    Current whip:
    RIP:
    Oct 23 2006
    Conshohocken, PA
    I requested a Water Pump made of entirely cardboard, but the dealership is on back-order for that particular design, so I have to go with the metal.
