Results 1 to 23 of 23
    Veteran Member Four Rings trueno429's Avatar
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    testpipe on jacks = fail
    ranting here..ive been doing well trying to get my cat out for the test pipe BUT..
    im on jackstands and i cant get the cat and downpipe out from under the car together..
    any tips on how i should cut the bolts from the cat-downpipe?
    theres no way im ganna be able to unscrew those rusted ass bolts.
    Veteran Member Four Rings gq9's Avatar
    Nov 07 2006
    02 A4 1.8t
    New York
    Re: testpipe on jacks = fail
    Did you try letting it soak for a good hour with rustbuster or something? Then try and crack them loose?
    Buncha motorcycles
    Memphis, TN
    usually there isnt even enough of the nut left to put a socket on, get a smaller one and hammer it on then try to break them off or chisel them off
    APR Stage 2/AWE Intake
    Account Terminated Three Rings lotusgardener's Avatar
    Dec 24 2006
    1997 Audi A4
    NW & NE
    unbolt the entire thing...
    make sure you took the airbox out...
    pull the cat out while rotating it clockwise...
    don't be bashful, pull forcefully and eat your wheaties...
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    yeah ive let them soak overnight..all the other bolts were easy to get off.
    its too cold outside and dark so im just ganna try again tmw morning.
    if they dont screw off im just ganna end up doing the dremel
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Sorry! Every time I read a post like this it confirms that paying my local shop $100 to install mine was the best money ever spent!
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    i cant pull the catout..i dont have enough ground clearance to rotate it out..if i had a lift im sure it would slide out easily so what im ganna have to do is unbolt the cat-downpipe on the floor with the cat halfway in the engine bay
    Veteran Member Four Rings Turbo1A4's Avatar
    Aug 04 2008
    2002 s4 nogaro
    Jax
    yea i would have taken it to a shop...try to heat it up with a torch(carefully)
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    Quote Originally Posted by trueno429 View Post
    pull it out the top, stand on a milk crate and pull it out. i just replaced mine on Sunday. take out the air box first.
    Senior Member Three Rings jessefrank's Avatar
    Jan 09 2006
    Q7.Prestige.S-line.Pkg.2
    Rapid.City
    I origionally did my test pipe on jack stands at about 55k on the clock...I know exactly what you are talking about. Those dang bolts were not coming off and there was no easy way to get the exhaust out because you couldn't get the car high enough to pull the entire thing out.
    I used a a combination of tools...started with a dremel to cut the bolt off (slowly was working, but it dosen't cut them off strait and I ran out of cutoff wheels). Then used a sawzall (worked the best but I burnt up all the blades I had and my neighbors). Finally used a modified air cut off tool to fininsh the job. All that and about 3 hours for only 3 lousy bolts.
    A lift is a bit more help...but it is still a pain in the rear because you have to cut those bolts off.
    Be paitient and take your time...you'll eventually get it.
    **Edit** also helps to have a set of stubby wrenchs for the new bolts, if not you can turn the two hard to get ones ever so slightly each time with a full size wrench.
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    haha thanks jesse frank, i got 76k on the clock
    but yeah i think i might try to take it off from the top good looks
    we'll see what happens tomorrow morning
    Veteran Member Four Rings 617 Bones's Avatar
    Wife's - MK3 GTI VR6 Vortech S/C
    Boston
    Quote Originally Posted by heateris View Post
    That's how I did mines!
    But you still have to be on jack stands cause the downpipe will be at weird angles while you are turning the downpipe/cat out of the engine bay.
    B7 A4 Avant 2.0T 6MT - Arctic | H&R + B5 Perches | JHM S/S + 4:1 Center Diff | Apikol Snub + Rear Diff Mount | Hawk HPS | Tyrolsport Caliper Kit | AWE Exhaust | 034 RSB + Spherical End Links | 19" VMR v710
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    on my B5, 2/3 of the bottom nuts on the cat>dp flange were spot welded onto the flange. so you could only get them out by taking the bolt out from the top.... so just to make sure, you're not trying to go at them from the bottom are you?
    either way i hated doing that mod. unbolting the transmission bellhousing from the block is easier than those damn 3 flange bolts, i swear
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    i cut my down pipe and pulled it out the top, was replacing the downpipe of course.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by lotusgardener View Post
    That IS the way to do it. Unbolt the entire exhaust and unbolt the CAT from the turbo. Get the car about a foot in the air on jack stands (nice 4ton Craftsman ones work well, they are super stable).
    You can then drop the exhaust to gain access to those CAT - Downpipe bolts and cut them off with an angle grinder. Then you can take the CAT out from up top and bolt the exhaust back in place.
    Install the test pipe with nice stainless steel bolts on that CAT - Downpipe flange and use locking copper lock-nuts or stainless steel nuts with NordLoc washers. Put a new gasket in too.
    I did this when I installed my cat-back to my OEM CAT and turbo. Followed the instructions on a4mods.com to get my cat off the turbo. Didn't take me that much time at all.
    -Doug
    Veteran Member Three Rings festerfm's Avatar
    Feb 07 2008
    just the a4
    northeast pa
    the first time we did mine (was just to replace a blown out gasket) we used a torch to cut off the bottom of the bolt and just replaced the hardware... to tighten it back up, my buddy cut his craftsman wrench in half so it would fit in the tight space. then when we put the test pipe in, same thing... used the half-wrench and an impact w/ extentions to unbolt the pipe, when you put it back in, it helps to have a friend help you since we dropped the whole catback... when we put the test pipe on, we bolted it to the catback while it was off the car then just had one guy hold up the exhaust and the other bolt it onto the turbo... of course, then took the wrench back to sears and got it replaced..
    Senior Member Two Rings Wanted's Avatar
    May 17 2007
    A4 Quattro, vert Z, Jeep XJ
    Louisville, KY
    Get some good quality heavy-duty cut off wheels for your dremel (or angle grinder if you have one) and don't waste anymore time soaking or trying to get the rusted bolts off. Then don't be shy about pulling the piece out - just manhandle the bad boy! Best of luck and keep us posted.
    1 more red A4, 3.0, 6spd Quattro...
    Now with a "free" Imola B5 S4 6spd
    Established Member Two Rings ExCarpi's Avatar
    Apr 06 2008
    2005 A4 1.8T 6sp
    Minneapolis, MN
    Try and find someone with a plasma cutter or a Oxyacetylene Torch. Then it will only take 5-10 minutes to get the bolts out.
    APR TIP, APR 1+, TT injectors, RaceTec FMIC, JHM Extra short throw shifter (45% reduction), ER Test Pipe, 19" OZ Ultraleggeras, B5S4 Front Calipers, Adam's Rotors with black hubs, Hawk HPS, PSS9 coilovers, Hotchkis Sways, clear corners, tint, Magnaflow Exhaust, Podi pod with SW boost gauge.
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    O used a dremel tool with one of the cable extensions to cut the bolts out of mine
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    ive never needed anything more than pb blaster and an impact with a swivel socket, but then again i have access to an air compressor/air tools, and live in sunny rust-free fl.
    like everyone else has said, take out the air box and get at least 2 nuts from the top, then pull it out from the top, rather than underneath.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Senior Member Two Rings Alphazuzu's Avatar
    Oct 05 2008
    Holly Springs, North Carolina
    I have the answer this is exactly what I did. Get the car up as high in the front and back as possible and you can get the pipe out. Just swivel it all the way to the drivers side and work it out. It helps to have someone above moving it for you. then cut the nuts and chisle them off.
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    haha thanks for the tips guys
    i couldnt get it out the top so i tried to get the bolts off from the bottom of the car, it wasnt bad as i thought after 76k
    i finished this morning and i noticed SUCH a diff..
    turbo sounds amazing, my dv sounds more noticeable, and the acceleration is pretty ill..
    but i got a exhaust leak because i couldnt tighten two bolts cuz i had no room..ganna need a lift for those
    Feb 07 2008
    just the a4
    northeast pa
    were they the 2 that are in a spot where u cant get a wrench on??? i've had issues w/ the gasket there and have had to tighten them b4.. you should have tightened those bolts before you put the cat back on the car... then with u'r exhaust as a whole bolt it onto the turbo... i mean, that was what i found to be the easiest..;.l
