Originally Posted by
bob12312357
You leave the N75 connected, but run a diode to fool it into thinking the boost is less then it is 2 prevent limp mode. So much mis-information in this thread. Talk 2 CincyTT on audiforums if you want the most info possible from someone who's done some crazy stuff with the stock ECU.
what about my post was mis-informative? the title of the thread is help with a MBC. it has nothing to do with the diode mod. i told him how to connect his MBC.
for a small (stock) turbo the TurboXS HPBC controler is a good choice, it has both a bleed type and spring type control mechanism that helps to eliminate spiking and surging.
