Originally Posted by
banger2392t1
I just bought a 01 s4 and the turbos seem realy quite and i can only hear them at low RPM's or going up a hill. I say this because i have a friend with a 1.8t and the turbos seem to be more pronounced. Do i have a leak? or are the turbos on the s4 just quite?? Thanks anyone who answers
first of all, its "quiet", and yes K03 are uber quiet, if you do the darintake mod, or piggie pipes or exhaust the sound is more pronounced.
If you had a leak, you might hear a whoosh, or if you have bad dv valves you might hear a whoosh.
Check your TBB for leaks and make sure everything is clamped down securely. Also you might want to pressure test the car to make sure you don't have a boost leak.
Install a boost gauge, it will help you keep an eye on boost, boost spikes and potential boost leaks.
