Results 1 to 2 of 2
    Oct 12 2007
    soon: 07 white Sline/titanium
    philadelphia
    ECT and Misfires? HELP
    So about 3 weeks ago CEL comes on its
    System Too Lean (forget the exact code).
    I take it to a shop and they found a cracked check valve. So he clears the codes replaces valve and everything is peachy.
    I then notice that when I start the car in the mornings, it doesn't rev to 1200 RPMs or whatever and it takes a long time to warm the car up. The next day new CEL comes on
    P3081: Engine Temp Too Low.
    After doing some research I decided to buy a new ECT sensor and top off the coolant (it was below the min line) So I replace the sensor (although the old sensor was green as well) and turn the car on. All of a sudden flashing CEL,
    Multiple Random Misfires
    Cylinder 2 Misfire
    Cylinder 3 Misfire
    Cylinder 4 Misfire
    I tried to swap 2 and 1 coil pack. No new Misfires on 1. Car drives fine. Although still no Cold Cycle start.
    My question is could the new ECT cause misfires? If not, what else do you guys think it could be.
    Nov 28 2006
    2005 Audi A4, Yamaha gp800 Watercraft
    CT, USA
    Re: ECT and Misfires? HELP
    maybe replace all coilpacks...thats just a guess...seems like you have other problems
