Results 1 to 12 of 12
    Senior Member Three Rings Greek Yayo's Avatar
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    power steering??
    i was doing donuts in the snow then i stopped, went to turn around and noticed i didnt have powersteering. i went and cheked the fluid and it was empty. i went and got fluid and filled it up. It doesnt leak, and i still dont have powersteering. is it the belt or the pump????
    Buncha motorcycles
    Memphis, TN
    Re: power steering??
    didnt someone make a joke about this very thing thing happening with all the people bragging about snow donuts?
    gee i was doing snodonuts and now my power steering stopped working
    OP, i would add some fluid ASAP, make sure its mineral fluid from the dealer
    APR Stage 2/AWE Intake
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    why does it have to be from dealer???
    Buncha motorcycles
    Memphis, TN
    its a special kind of mineral fluid... if you can find a approved fluid anywhere else you can certainly use it, just check the book for specs
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    p/s pump did the same thing
    Veteran Member Three Rings ridelikeme's Avatar
    Jun 15 2005
    B6 A4 , Avalanche LT,
    Calgary
    haha you burnt out your power steering pump. those pumps when steered lock to lock burn out in under 30 seconds.
    Veteran Member Three Rings ziggituning's Avatar
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    I find in cold weather when pushed from max to max, the power steering system is not very good, so when doing snow D's, relax on the steering, or do as I do and avoid making the donuts!! Likely blew your pump.
    PARTS FOR SALE: LW Crank Pulley, OEM injectors, ABT rep grill, OEM Intercooler, PM me.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM![/SIZE]
    Jun 08 2008
    Calgary AB Canada
    pwned.
    Veteran Member Three Rings Trev's Avatar
    Nov 25 2007
    b6 a4tq, 95 Eagle Talon (Rip)
    British Columbia, Canada
    HEHE couldn't resist
    Some Go, No show
    02 Qtip, Apr II+ 93Oct, tt-225 injectors, Ecode fmic, W/M Injection, Magnaflow 16601,TT225 Down Pipe, VMR test pipe, APR TIP, Forge 007, Vag-Com, Podi V2, RS4 LSB, ECS Snub, USP front lower, S4 Front Brakes, Slotted/Dimpled Rotors f/r, SS Lines f/r, 19x8.5 & 19x9.5 RPM 505's, RNS-E
    Wish List
    Custom fab intake heat shield, Custom fab system in trunk, Adjustable Coilovers, S4 blades, DTH side skirts
    Veteran Member Four Rings El_Chapusca's Avatar
    Jun 06 2008
    Long Island, NY
    mAKE SURE ITS HYDROLIC POWER STEERING FLUID
    -Joey aka Chappy
    GCC Law/Rule #22 Enforcer.
    GCC: Its Serious Business
    Tastefully Modded
    Oct 27 2008
    Studio City, California
    im pretty sure its ur pump audi has replaced 4 on my car so far ive had the car for about a year and a half.. :( they tend to go bad i guess but i have FWD CVT and dont do donuts or anything..
