Results 1 to 9 of 9
Thread: Extra nuts
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Extra nuts
    Well I have put my car together and I have these three extra nuts. A friend took them off and now no one remembers where they go. Any ideas?
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    Re: Extra nuts
    They look like the nuts for the heat shield around the drive shaft
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Re: Extra nuts
    they look like the nuts that hold the AC accumulator on (behind the passenger intercooler)
    Veteran Member Three Rings festerfm's Avatar
    Feb 07 2008
    just the a4
    northeast pa
    Re: Extra nuts
    look like extras.. leave them out... less weight will give you faster 0-60, 1/4 mile times, and better mileage..
    j/k.. i havent a clue.
    Veteran Member Three Rings 2ndEngineS4's Avatar
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    Re: Extra nuts
    Quote Originally Posted by infinkc View Post
    x2.
    JHM.Vast.034.ER.SR.AWE.RS4.Apikol.APR.Innovate.Stg III
    Veteran Member Four Rings Quattrocket's Avatar
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    Re: Extra nuts
    i agree look like the driveshaft heat shield nuts.
    MITCH
    "Audis are like strippers. They only work when you throw money at them."
    FORGE MOTORSPORT DVs*K04 TURBOS*034 TURBO INLETS*STAGE 3 SOUTHBEND CLUTCH(MANGLED PP MOD)*
    Active Member Four Rings ///M3 TO S4's Avatar
    Feb 09 2007
    Charlotte, NC
    Re: Extra nuts
    Quote Originally Posted by Dimcorner View Post
    +1, that would be my guess too...
    Learn MANTH America!
    Stage 3....blah...blah...blah... : Sold
    Now: E36 M3 TURBO (GT35R)
    Veteran Member Four Rings Mooseimage's Avatar
    Feb 15 2008
    2007 Audi A4, 2017 Audi SQ5
    Sacramento, CA
    Re: Extra nuts
    Well, its not too strange anymore to have a 3rd nut, many people in society do...
    I kid, I kid. Agree with both options, could be for heat shield or A/C accumulator. Check both.
    GCC Rule #22 Enforcer
    marty was here: id stay away from the womb that gave birth to fail
    2007 Audi A4 2.0T MT Avant: JHM Stage 3 goodness
    2017 Audi SQ5: Stock (for now)
    Jul 06 2007
    San Jose, CA
    Re: Extra nuts
    That was it. Thank you very much everyone.
