Results 1 to 10 of 10
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    Stock sport suspension bouncing?
    I have the stock sport suspension and lately ive been noticing that it is bouncing significantly at freeway speeds over expansion joints. Anyone else having this problem? Sometime i feel like im bouncing out of my seat.
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Re: Stock sport suspension bouncing?
    sounds like your shocks are gone... great time to upgrade to coilovers
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Quote Originally Posted by a4dc89 View Post
    how many miles are on your car?
    i have a problem with this too, but i only have about 28k miles. i really don't like the stock sport suspension. dampening is fine, rebound is terrible.
    coilovers are on their way pretty soon for me, along with an RS4 rear swaybar.
    Dec 07 2008
    Harrisburg, PA
    I have noticed this but it's not really bad unless it is very cold outside. All cars ride different in cold temps.
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    Quote Originally Posted by p1nk50ck View Post
    yeah, the rebound is absolutely horrible or it could be my shocks are done at 31k miles which doesnt make much sense.
    All go no show
    Senior Member Two Rings unh112's Avatar
    Jan 18 2008
    06 A4 2.0TQ Manual
    Boston, MA
    same thing happens to me, so i bought some koni fsd/ eibach spring to upgrade the shocks.
    06 B7 Quattro Silver MT
    RS4 Sway Bar | RS4 pedals | S4 Door blades | Votex front spoiler | Votex rear spoiler | revo stage 1 | Forge DV | clear side markers | VAG-COM mod | Eibach pro kit | Koni FSD | 40% Llumar axcess tint | LED license plate light | 6000K HID | 18's B8 wheels 245/40/18 tires with 8/12mm H&R spacers front and back
    Dec 14 2006
    2007 Audi A4 S-Line
    Long Island, New York
    I'm starting to get the hood hop as well.. :(
    Mar 05 2008
    PA
    I'm having the same issue along with squeaking/creaking noise. Is this suspension related? Or is it due to the cold weather? I'm non sline, with stock suspension (4x4 as everyone calls it).. thanks in advance..
    2006 A4 2.0T Quattro
    Quartz Gray Metallic
    Jul 20 2008
    Chicago
    Quote Originally Posted by unh112 View Post
    Ditto. This combination provides ~1.5" lowering from stock (which is ~.5" lower than Audi sport) with a big improvement in handling AND comfort.
    The bounciness you feel is likely the internal stock-shock seals losing their effectiveness and amplified by colder temperatures buckling the road surface.
    The Koni FSD are automatically reactive to road conditions and will firm up immediately if you throw the car hard into a turn yet still give for large tire-hop types of bumps which keeps the tire planted...perfect for street performance.
    The Eibach Pro (progressive) springs lower your car but, due to the progressive nature, increase the spring rate the more your car is loaded down (i.e passengers or hard turns) yet the initial rate of their travel is light enough to soften the jolts of even the most jarring railroad crossing or expansion joint.
    Veteran Member Four Rings Koby's Avatar
    Aug 05 2008
    Easton, PA
    Quote Originally Posted by Bmeister View Post
    Good info man, thanks! Nice to see a suspension post that isn't the typical knee-jerk "coilovers" comment.
