Results 1 to 7 of 7
    Jun 20 2008
    Vancouver
    HELP!! What's wrong with my car...
    with 16k kms on it.... i had my first CEL last night...
    and after a couple of hours...when i restarted the car again...
    the light goes off...
    anyone has experienced anything like this when their car is less than a year old??...
    i really dont think much could happen with a car with 16k kms on it...
    should i still bring it in to the dealer??TIA...
    Senior Member Three Rings kastro's Avatar
    Mar 20 2008
    04.5 1.8TQ Tip A4 Black -
    Ottawa, Ontario
    Re: HELP!! What's wrong with my car...
    is the driving quality effected in any way??? check ur manual if ur due for anything(spark plugs/coil packs)
    i have a b6, can't check for u, another thing is, get someone local on the forum to vagcom ur car, it'll shoot out a code then u can determin were to go with that..
    OEM is sexy.
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    happened to me before. audi reliability ftl
    are you stock?
    Veteran Member Four Rings nramsey's Avatar
    Dec 09 2004
    Might just be a loose gas cap. I'd wait to see if it popped back up again, then take it to the dealer.
    - Nathan
    http://www.flickr.com/photos/nramsey
    2008 A4 2.0T Quattro Avant - Dolphin Gray
    Eibach Pro-Kit - Koni FSD - Rotiform MIAs
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    Quote Originally Posted by nramsey View Post
    An Audi Tech told me that 90% of CELs are loose gas caps. If it went away, that's prob what it was. If it's still driving fine, just have them run it for codes next time it's in for service.
    Jan 01 2008
    Long Island NY
    probably fuel pressure sensor or intake manifold flap.
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    see sticky of common problems with the 2.0t its bound to be one of them if it isnt the gas cap
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
