Alright guys, i took my car to the audi dealership to get an alignment because i had just bought 2 new front tires and even before the new tires the car would pull to the right, and i had to have the steering wheel a little to the left so the car would go straight and i could tell the alignment was off.
So i take the car in and they do the whole aligment to then at the end tell me that my outer tie rod ends were torn, but were not loose or affecting the alignment at the moment but still should be replaced. They said that they got the alignment as close to spec as they could but they coulnt get it perfect because my car is lowered.
SO long story short i convinced them to refund my 150$ because they performed the alignment without telling me that i had to replace the tie rods.
then when i take the car on the road and the alignment seemed alot better than before but still pulled to the right at high speeds. Right after the alignment i went and got the tie rod ends replaced and also the driver side front axle and the mechanic said that he would count the number of threads on the tie rod so he can replace them in almst the same position so i wouldnt need an alignment
So now the car still pulls to the right but now i need to have the steering wheel even more to the left in order to go straight. so The steering problem got slightly worse.
Do you guys think i should still go get another alignement? or should i just listen to my mechnic? can the alignment fix my crooked steering wheel or is somethign bent in there? can improper installation of the tie rod ends cause the steering wheel to be crooked? thanks alot guys
