Results 1 to 7 of 7
    Senior Member Three Rings 03CrysBlueB6's Avatar
    May 12 2008
    washington
    coolant question??
    two actually.. coolnat light has been coming on when cold start.. i think its time for some fluid.. can i only use the fluid sold at audi dealerships?? and if so how much does it run?? tried searching but couldnt find anything
    B5 A4 - silver [gone]
    B6 a4 - Crystal Blue [current]
    FS: B6 A4 sport struts with about 30k on them
    WTB: S4 or USP front
    Door Blades
    Rear Lip Spoiler
    USP or other Rear
    Active Member Four Rings juggernaut201's Avatar
    Dec 12 2008
    06' A4 2.0T 6MTQ
    Jersey
    Re: coolant question??
    you can also use water wetter ... sold at pep boys and autozone ... help keep it cooler iv been runnin it 4 a while no issues .... during idol my car can b fully warmed up and as it just sits there the temp gauge acually goes back down if it sits for about 3 or 4 mins in this weather
    Dec 12 2008
    06' A4 2.0T 6MTQ
    Jersey
    and i think the gallon of audi coolant is like 30 from the dealer i have some in my garage
    Veteran Member Four Rings mattman's Avatar
    Oct 23 2007
    1978 Honda CB400T Cafe Racer
    Ontario, Canada
    a Gallon of G12 from the dealership is all you need (and water of course). It was roughly 35$ CAD.
    Meet Shanice...
    For Sale:
    Stock suspension, slightly damaged stock painted lower front
    Veteran Member Three Rings miggity02's Avatar
    Mar 22 2008
    '17 SQ5, MK7 GTI
    East Bay, NorCal
    I'm not sure about the coolant light, but a gallon of G12 costs me just over $23 USD at the dealership. I wouldn't put anything else in there.
    '17 SQ5-034 Stage 2 ecu/tcu-JHM 187mm CP-034 inlet, RSB, sub frame inserts-Eurocode trans/diff mounts-Alu Kreuz-B8/H&R-Neuspeed RSf72 20x9.5 et25-Magnaflow 11385-OEM airbox mod-aFe 11-10121
    Mk7 GTI-034 Stage 1 ecu/tcu-H&R springs/B8-Neuspeed rse11r
    Triumph Street Triple R-Full Arrow and tune
    Veteran Member Four Rings zz2h33's Avatar
    Jul 28 2008
    2002 Avant 3.0L
    Chicago, IL
    it should be mentioned that the gallon you get at the dealer makes 2 gallons mixed 50/50. and use only the G12, do not mix anything else in there even if it says "all makes/all models."
    02 Avant 3.0 // Avant Garde Member // 3.0 Group Member
    Veteran Member Four Rings 3ohAvant's Avatar
    Mar 10 2004
    east bay, CA
    Quote Originally Posted by juggernaut201 View Post
    really? you use this stuff? I was told that using this will clump up when mixed w/ g12.
    OP: you can top off with G12, doesn't have to be from the dealer. Your local indy parts supplier might have some G12 Pentosin.
    - Benny
