Results 1 to 29 of 29
    Veteran Member Three Rings fritzner's Avatar
    Nov 30 2006
    05 Red USP Avant 1.8T 6spd
    Pittsburgh, PA
    podi mechanical gauge night pics.. (with 1.5k ohm resistor)
    Winston does not disappoint.. i love my new S&D podi + mechanical gauge..
    -- the S&D podi looked nearly flawless..
    -- the new mechanical gauge looks great too..
    -- no buzzing at all with the 2 supplied antibuzz fittings installed..
    -- the gauge was just a little loose, but a 2" piece of electrical tape on the bottom of the gauge cured that..
    -- when i tightened the 90* vacuum line fitting (to the back of the gauge) it pointed into the side of the podi, so i had to back it off a 1/4 turn.. i had some plumbers tape around so i thru it on to insure no leaks and it does not seem to be a problem..
    -- the gauge lighting is a little more blue than the dash, but for the price and quality otherwise, i can definitely live with it..
    -- as known the gauge is a little bright.. i added a 1.5k ohm 1/2watt resistor and it is much better.. ($0.99 for a pack of 5 at Radio Shack).. here are some pics..
    >'05 Brilliant Red A4 USP Avant 1.8T 6spd
    ...REVO-II | TT injectors | RS4 sway | RS4 Pedals | podi
    ...Moven SP-10 (sportec reps) | 3.0L brakes | RNS-E | coolbox
    ...USP CLUB MEMBER #118
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    Re: podi mechanical gauge night pics.. (with 1.5k ohm resistor)
    great thread man, i was just looking for this exact information! do you know of anywhere else to get just one single 1.5K ohm 1/2 watt resistor for a decent price?
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Looks great! I agree, the fitment is fantastic with the Podi.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Quote Originally Posted by LampyB View Post
    $.99 for 5, are you so cheap you only want one?
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    well he probably read the OP, which stated it was $99 for a pack of 5, which would be ridiculous hahah.
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Nov 30 2006
    Pittsburgh, PA
    Quote Originally Posted by Molotov View Post
    oops.. posted a bit late last night and forgot the very important decimal point.. i edited the original post with the correct price of 99cents for a pack of 5.. thanks..
    also i should have added that many have said 1/4 watt was sufficient, but my Radio Shack only had 1.5k ohm in 1/2 watt..
    you also might want to pick up a short piece of shrink tubing..
    now i just need REVO stg2 to better exercise the gauge..
    Apr 25 2007
    MA
    Haha last night it read $99!!! I almost crapped in my pants at that price
    Mar 21 2006
    Lakeland, FL.
    I know, it was an obvious typo, but he should have known that. If a resistor was $20, imagine how expensive electronics would be.
    I'm back bitches!
    Feb 24 2007
    Burlington, Vermont
    haha yes I know, but most of us don't think before we post. We read that and think "holy balls that's expensive" instead of "holy balls WHY is that so expensive"
    - Scott
    Das Build Thread
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Thanks for posting this up for everyone.
    Apr 25 2007
    MA
    or i was about three hours past when i should have gone to bed...
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    nice. that's what mine has ended up looking like with three 470's in it. same brightness but just a little bit of blue tint to it.
    still a millions times better than that SW guage was.
    thanks again winston!
    oh, and did you get the silver guage bezel? im glad i opted for that as well. looks great. and i don't know what everyone was freaking out about for
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    Winston We Need The Dual Gauge Pod!!
    Jun 11 2005
    Vancouver, BC
    The p2 is coming
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    If you had added a 1 watt/1.5k ohm resistor how would that effect the light output?
    -Sami-
    Jun 11 2005
    Vancouver, BC
    Is is the resistance which reduces the light output, not the power rating of the resistor (wattage)
    If you used a 2300ohm resistor the light output would dim even more.
    The power rating determines how much power it can dissipate.
    For example... the cityLED resistor mod.. I used a 1W resistor and the resistor does get warm absorbing all the excess current to protect the LED.
    If you replaced it with the same resistance value but used a 1/4W power value it would get hot and heat is the enemy here.
    If you put a 5W resistor in there the resistor itself would operate very cool and you might not feel any heat at all.
    Veteran Member Four Rings KPC1.8TQuat's Avatar
    Mar 20 2006
    2003 A4 1.8T Quattro, 2006 Triumph Daytona 675
    North Shore, New England
    I need to trade in my Stewart Warner for this one....This is what I thought the SW would look like.
    Senior Member Two Rings 02A4_B6's Avatar
    Dec 08 2005
    installed an Omori center vent gauge kit and tied the white 12v ignition (for dimming capabilities) into the grey and whit wire of my headlight switch. quick question....i bought the same resistors you did and tied one into the white wire of my gauge. it dimmed the light output but it turned my white backlighting into red? is it possible that i put the resistor in backwards? any ideas?
    02 A4 1.8T QUATTRO 5SPD
    87 COUPE GT 5SPD.....SOLD
    00 CIVIC SI 5SPD....TOTALED
    86 GTI 16V 5SPD...SOLD
    Nov 30 2006
    Pittsburgh, PA
    resistors are non-directional, so that is not the issue.. not sure how it turned it to red??..
    Dec 08 2005
    im wondering if the resistor somehow duplicared rge color of the lighting of the headlight switch. it boggled my mind like no other. it dimmed but turned red...lol
    Senior Member Two Rings JPC1.8t's Avatar
    Apr 06 2009
    03 A4 1.8TQM 97 Arctic Cat ZRT 800
    Did you ever solve the problem of your backlight changing to red? Finished my install with the resistor and the same thing happened to me lol. Wonder if there is a specific spot it needs to be. Although the red doesnt look too bad matches all the red where it sits.
    Jun 11 2005
    Vancouver, BC
    it took over a year for me to get them but the silver bezels have finally arrived!
    So what was the name you palced your order under so I can look it up.
    What gauge are you using?
    Apr 06 2009
    Its an Omoni from the ecs vp kit.
    Jun 11 2005
    Vancouver, BC
    I don't know if the current Omori gauges are the same design as the old ones, I say this since Omori Meter Japan went out of business 2 years ago, but the original ones has a setting where if you shorted out two of the pins with a supplied resistor pack it would set the gauge to a 'default' color.
    I have one which turns amber orange and another that turns green.
    Senior Member Three Rings 04_A4_1.8T's Avatar
    Apr 13 2008
    04 Audi A4 1.8T
    Utah
    Quote Originally Posted by [email protected] View Post
    The p2 is coming
    WHEN WHEN WHEN WHEN lol im somewhat patiently waiting
    My Cars...
    1998 Honda Civic Ex... *sold*
    2004 Audi A4 1.8T Giac Stage 1+ *current*
    *Honda Cbr 600rr* Springtime
    Apr 06 2009
    Alright thanks for the help, probably what is going on.. I don't mind the new color it matches the rest of the interior red perfect, only thing is it's a little hard to read at night, but with a pretty much stock ko3 I don't need to read much...yet lol.
    Dec 20 2009
    melbourne, fl
    Ya just purchased this and it is a top notch product.
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    Quote Originally Posted by pjaaudi03 View Post
    Thanks for your support
    Dec 19 2007
    York, PA
    wow, i wish my gauges lighting looked that well...you can actually see the needle :)
