Results 1 to 10 of 10
    Active Member Four Rings juggernaut201's Avatar
    Dec 12 2008
    06' A4 2.0T 6MTQ
    Jersey
    headlight fogging
    ughhh what do i do
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Re: headlight fogging
    Some say it is normal, if you want it gone wait it out or use a hairdryer through one of the holes after you pop off a cap on the back. If you have opened your headlights before then I'm guessing you didn't seal it back up well enough.
    Veteran Member Three Rings sdjeff's Avatar
    Jun 04 2008
    B7 A4 2.0t, Dino 246 GT
    RSF san diego
    You can try dropping a sicilia packet in the back of the housing.. might soak up some of the moisture.
    Oct 16 2008
    South Florida - Ft Lauderdale
    Quote Originally Posted by juggernaut201 View Post
    ughhh what do i do
    Send them to me and I will fix them for you
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    Did this just randomly happen or did it happen after you opened up your headlights?
    This happened to me after opening my headlights to black them out. One sealed back up just fine with what was left of the glue from the factory. However, the other one fogged up a lot. I bought some silicon window sealant and applied it around the whole edge of where the headlights seal together. I haven't had any fogging since...
    05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
    The only standing start, straight line racing I enjoy is on the way to the first corner.
    Dec 12 2008
    06' A4 2.0T 6MTQ
    Jersey
    thx it happened before and after the cc mod to the same headlight i opened the back now and im letting the heat get 2 it ... im gunna cose it up and we'll c wha happens hopefully it doesnt happen again .... what sealant should i use if it does?
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    Seal is bad. Generally happens when you open up your headlights etc. Who knew these things weren't meant to go in the oven? Just clean them and seal them using a plastic sealant. Make sure you let them dry out beforehand though.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    100% pure silicone (like for aquariums) works the best IMO but you could get any exterior sealant from home depot. FYI white looks the worst. Get black or clear if you can.
    Oct 16 2008
    My 2 cent:
    Because I open quite a lot of headlights with the LED Strip conversion, I do not use any silicone but the same original compound (Butyl) and I don't have any issue.
    Veteran Member Four Rings xander3zero's Avatar
    May 30 2013
    Rhode Island
    My 2 cent:
    bumping this thread back from the dead...
    Phil, can you provide a link, part number, etc of the sealant you buy?
    almost 2 years after CCing my headlights one of them is developing some moisture...FML
    2017 Audi S3
    Mythos Black Metallic | Dynamic Package | Tech Package | S Sport Seats | Bang & Olufsen
    Previous:
    2013 Allroad Premium+
    2006 A4 Quattro 6MT
