Results 1 to 3 of 3
Thread: Shifting issue
    Veteran Member Three Rings b5andm3's Avatar
    Aug 22 2008
    Central Maryland
    Shifting issue
    I am hardly new to driving standard. See Sig for other car.
    In the mornings when it is a bit nippy outside, shifting from 1-2, occasionally feels as if the shifter is either a) getting caught or b) the clutch is partially engaged. The clutch shows no signs of slipping and the usual culprit throw out bearing noises are no where to be heard.
    The PO installed a B&M SSK. Is this a notoriously notchy kit? Its only bad on the 1-2 and sometimes 2-3.
    Other times when I push in the clutch to put her in first I have to do it twice in order to get in first.
    What gives? Sorry for the confusing post. I am on nyquil ugh..
    2000.5 A4Q - 2871r / 1.9L Stroked / IE Rods / JE Pistons / 3.5" TBE Exhaust / Forge MBC / 630cc Injectors / Walbro 255lph Fuel Pump / VR6 MAF / Unitronic Tune / CM FX600 / ECS N75 Race Valve / ECS 9lb Alum Flywheel / Forge TIP / Forge DV / ARP Head Studs / BBS LMs / RS4 Front Bumper / Hagus Mirrors / Brembo BBK / RS4 Shift Knob / JL Audio Speakers, Subwoofer & Amplifier / Clarion NX409 / HR Race Springs / Evolution Racewerks FMIC
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    Re: Shifting issue
    welcome to the club... Cold shifts from 1-2 are always rough in our cars. My car has zero issues trans wise and with it now being 16degrees at night while my car isn't warmed up i have to go from first to neutral to second to make it smooth for first couple shifts. theres probably nothing wrong, its common..
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Shifting issue
    Quote Originally Posted by b5andm3 View Post
    a bit nippy outside
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
