Results 1 to 11 of 11
    Senior Member Three Rings B00sted20VUSP's Avatar
    Nov 11 2008
    Junk
    Chicago, IL
    APR Stage 1+ Question?
    Hey guys, this is just a quick question, i have APR Stage 1+ and the associated mods in my sig. Now ive had it for about a year now, never really raced anybody, but i raced my buddys stock 5spd 02 A4 and i only took him by about a little more than a car. I know my car feels faster but, i dont know if im getting the full potential of the upgrade. Do you guys think an exhaust would have a noticable gain, and what suggestion? ie, test pipe or not?
    Thanx guys
    /S4 25 Quattro #139 | JHM 93 Oct Tune | Fast Intentions Non-Res Exhaust | Trexturk Downpipes | VMR Staggered Gunmetal 710's | RS4 Grille | RS4 Pedals
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    Re: APR Stage 1+ Question?
    You would benefit most from a FMIC. The stock intercooler cannot provide adequate cooling and heat soaking happens. You'll feel a big difference with a upgraded intercooler even in the Winter temps.
    An exhaust would also help.
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Also an upgraded clutch would greatly help ur ability to launch and utilize your much superior torque potential out of the hole.
    Go here and get some gud condensed knowledge:
    B6 A4 Ultimate Performance Noob Writeup/FAQ
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Part of it could be that he just "outdrove" you - launching and shifting.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Senior Member Three Rings jessefrank's Avatar
    Jan 09 2006
    Q7.Prestige.S-line.Pkg.2
    Rapid.City
    The 5spd has slightly different/lower gearing as well...could have factored into it as well.
    I have REVO and have added parts slowly, but the 1+ file would def benefit from a FMIC/DSMIC and exhaust/TP.
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    Exhaust would benefit and as well as an intercooler too!
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Definitely need a bigger intercooler. Even a stage 1 will need a better intercooler. My stage 1 heat soaked in freezing temps in the garage when it was on the dyno. Exhaust with an upgraded downpipe will also help a lot. The downpipe is key though witht he exhaust
    Nov 11 2008
    Junk
    Chicago, IL
    Thanx guys, always a Big Help!!
    Veteran Member Four Rings A4 KiDD 810's Avatar
    Aug 25 2007
    B6 S4
    Westchester, New York
    an exhaust will def. help alot because fmic or not you don't have the room to be pushing out as much as the car wants to w/o an exhaust. if you got just the fmic you'd be running too rich so get both, or just the exhaust. I've heard 15hp from exhaust probably near the same from fmic a testpipe should add around that too. I know apr 1+ claims 235 crank I have it too and I talked to the tuning shop owner who said he knows the founders of apr personally and they don't puff their numbers, but there is no way we are running that without an exhaust fmic or both. I don't have either right now but I will before waterfest rolls around but I do have a bailey dv and a sb stg1 clutch. anyway good luck.
    -Nick
    -2004 Brilliant Red S4 6Spd - Thermal R&D Catback, FK Coils, Piggie pipes, JHM Tune
    -2002 Brilliant Black 1.8T 5Spd - (traded in) Gone but never forgotten
    Registered Member Two Rings mu5tang0's Avatar
    Aug 14 2008
    02 A4,05 v8 t'reg,93 mustang
    Chicago, Il
    me being the "buddy" he raced all i got to say is learn how to drive....o yea and i would like to add "good thing your a professional"
    Established Member Two Rings Plasticar's Avatar
    Jul 08 2008
    B6 A4Avant, B5.5 Passat 4mot
    West Bloomfield, MI
    I am wondering if it could be partly due to his having a 5 speed and yours a 6 speed? Differences in gearing could make them pull differently. By race, I assume you mean a couple of stoplights or maybe a mile or so?
