Results 1 to 9 of 9
Thread: clutch
    Dec 30 2008
    western mass
    clutch
    So I did a search and found information for later model audi's. So i'm hoping to get some info for a b7. here it goes...I've been searching for a b7 audi for a while, finally found one that im supposed to be picking up tomorrow morning. I test drove a 06 from the audi dealership, car felt great but price was too high. So the car im picking up is from a dealership called automax (maybe some of you have experience with this dealership and will tell me not to buy from them) but when i test drove this car which is a 2005.5, the clutch seemed to kick in higher than the 06 did. it really got me questioning whether the clutch is going bad or not. i did the usual tests like tried starting from 5th and 6th gear and car just stalled out and also dumped the clutch in 6th and the car stalled out but it really bothered me knowing that the clutch didnt feel the same. does anybody have any input on this. I'd greatly appreciate any information. thanks
    Senior Member Three Rings Blarg's Avatar
    Sep 08 2008
    Kansas City
    Re: clutch
    I believe the clutch auto adjusts so it always releases at the same point. So it doesn't matter how worn the clutch is, the engage point will be the same. I hope that helps, I'm worried about mine going out because of the cost but I'll just take care of it and hopefully it will take care of me...
    Sold - 2006 A4 S-line Quattro 6M Nav
    Dec 30 2008
    western mass
    Re: clutch
    Thanks for the input, helps out a bit. Any other knowledge from anybody else?
    May 22 2008
    St Clair Shores, MI
    Re: clutch
    Maybe the first one you drove was going out and this one is the good one. FWIW, I have never had a clutch feel the same, even with close to the same amount of miles on the same model car. Everyone has a different style of driving and this causes clutches to wear differently. A better test, at least for cars with big low end torque, is putting it in a higher gear at lower speed and going WOT. Given the tests you did, I would think it would be fine.
    13 S4 Monsoon Gray - 6MT l sports diff l Nappa l Atlas l EPL Stg2
    DP l MercRacing HX l iAbed TB l Sach's Xtend l AWE Track/Touring w/ res DPs l 034 Xbrace & drivetrain mounts l P3 Track
    Dec 30 2008
    western mass
    Re: clutch
    That is true...I've owned nothing but manual transmission cars, including a modified vw and my last car was a g35 coupe...both cars felt completely different from this one but yes I know, they are completely different vehicles. I just wanted to make sure before I bought this car. Thanks guys
    Dec 01 2007
    Markham, Ontario
    Re: clutch
    Quote Originally Posted by SpoolinPelican View Post
    if the clutch was fine .. with this test.. the car should move or stall ?
    2015 BMW M3 Alpine White
    2013 Phantom Black RS5
    2012 Audi TTRS Black / Black - Sold
    Plus One
    Gabriel
    3255 Highway 7 East Unit 159
    Markham Ontario
    Cellular sales / repairs / unlocking / flashing - PM if you need help with anything
    Veteran Member Three Rings sdjeff's Avatar
    Jun 04 2008
    B7 A4 2.0t, Dino 246 GT
    RSF san diego
    Re: clutch
    Quote Originally Posted by evilgabbie View Post
    With a good clutch it will bog..
    Senior Member Two Rings Nobuttsechs4me's Avatar
    Dec 17 2008
    Orlando
    Re: clutch
    What would the symptom be of a worn clutch with that test be?
    Veteran Member Four Rings nramsey's Avatar
    Dec 09 2004
    Re: clutch
    The engine RPMs will increase but the car won't accelerate. This is the clutch slipping...
    - Nathan
    http://www.flickr.com/photos/nramsey
    2008 A4 2.0T Quattro Avant - Dolphin Gray
    Eibach Pro-Kit - Koni FSD - Rotiform MIAs
