Results 1 to 21 of 21
    Veteran Member Four Rings zz2h33's Avatar
    Jul 28 2008
    2002 Avant 3.0L
    Chicago, IL
    ESP light staying on
    TIP trans.
    The car has been acting up the past week or so. When its cold, the ESP light stays on and it drives weird, like it has no torque in first gear. Does this in TIP or in D. It shifts fine, it just feels like it has no low end power at all. Once I drive it for a while, and the trans gets up to operating temp, it seems to be fine, I can shut the car off and the ESP light stays off. I'll park it for a few hours and it does it again. No CEL. Any clues? Please dont say the trans or TC are screwed.
    02 Avant 3.0 // Avant Garde Member // 3.0 Group Member
    Jul 28 2008
    2002 Avant 3.0L
    Chicago, IL
    Re: ESP light staying on
    I talked to my Audi mechanic friend and wow i would have never have guessed his prognosis. looks like its the brake light switch acting up. he said that if the ecm thinks you are braking and giving throttle at the same time it will pull fuel, and that is exactly what seems to be happening. so i went out, started the car and left it in Park (the ESP light would never come on at this point, seemed only after shifting into drive the ESP would go on). So i just pressed the brake and released it and sure enough the ESP light went on and stayed on. The brake lights are functioning correctly tho, but he says there is a separate circuit that feeds the ecm. So, sounds like i need to replace the switch. Anyone done this? looks like a PITA, I cant even see the damn thing without my inspection mirror. I think i'll have him do it.
    Just an FYI for anyone else that might run into this. Weird symptom for this issue.
    Senior Member Three Rings Sp3C14L 3D's Avatar
    Aug 17 2008
    2005 A4 1.8T Ultrasport
    wow thats so weird
    USPCLUB MEMBER#724
    Established Member Two Rings taydam's Avatar
    Jan 11 2008
    Regina, SK, Canada
    yup should be the break light switch, same thing happened to me a couple weeks ago ... i dont understand how it works either but that was the problem
    Veteran Member Four Rings gq9's Avatar
    Nov 07 2006
    02 A4 1.8t
    New York
    Yeah common problem, faulty brake light switch. Replaced under warranty.
    Veteran Member Three Rings CTUltrasport's Avatar
    Jan 25 2007
    2005 Audi TT
    Greenwich, CT
    Same exact thing just happened to me. My ESP light was coming on randomly while driving, then would be gone after the next start up. I thought it was really odd so I took it to Audi. They said they were finding a cyl #2 misfire...ended up not finding a fix for it, so Audi replaced the engine block. 4 weeks later, I get the car back and sure enough the ESP light pops on again. Took it back to the dealership and they stated that there has been an intermittant brake light switch error. They didn't replace it and rather cleared everything and sure enough as I was driving home it came on again. I am fed up with taking it back down there, so I am just going to wait to do it during my next oil change or something.
    2013 Audi S4
    Veteran Member Three Rings 04TurboB6's Avatar
    Feb 17 2008
    Leesburg, Va
    i was having the same problem...it turns on....while im driving...the next start up its off....then on...and off.....didn't know the brake light switch could cause that
    Veteran Member Three Rings tdmopar59's Avatar
    Jun 23 2008
    05 A4q 1.8t 6mt
    haha same exact problem here was gonna post about it and just read this... any idea how to replace this??
    05 1.8t 6mt | itg filter | bailey dv | UNI flash | USP front | e-codes | stay tuned
    help me buy more parts!! Any work you need in SE PA area on your car or with construction let me know!! (PM me)
    Mar 12 2008
    CHI-TOWN
    i used to have the same problem and i drove on it til my trans blew then got everything fixed and my mas air flow wen bad again on on came that esp light again so its back in the shop
    Dec 01 2008
    2002 Audi A4
    My ESP light comes on after about 10 minutes of driving and will stay on until I turnthe car off. I took it into the dealership and they found nothing wrong, and claimed the light never came on for them. Sure enough as soon as I leave the dealership, 10 minutes or so and the light is back on. After speaking to a few members they recommended I check my MAF / clean it as it could be the problem. I haven't gotten around to it yet, however, I would definatly check it out and let us know how it goes.
    Dec 12 2008
    Minneapolis
    I've ran into this problem also. It started when the weather here was in the negatives. I yet need to check the brake light switch and the MAF sensor. I'm leaning towards the problem coming from the MAF because of the rough idle during cold starts.
    I will stop procrastinating and check it out this weekend and let everyone know what happens.
    Jul 16 2008
    05 Avant 1.8t Qtip
    Toronto, On
    happened to me as well, apparently its a common problem, and the part is like 5 bucks
    Active Member Two Rings shawn120's Avatar
    Nov 04 2007
    Vancouver
    I have had the same problem periodically for the last 6 months. I will come on randomly, and stay on until I restart. I have had it into the shop twice, and they tell me no errors show up. If anyone finds out the cause, please post it!
    Thanks
    Jun 23 2008
    05 A4q 1.8t 6mt
    cleaned the MAF sensor tonight and i still have the same problem... I'm gonna try the brake light switch or whatever tomora night hopefully
    Jul 28 2008
    2002 Avant 3.0L
    Chicago, IL
    its for sure the brake light switch guys, when i start my car the light is off...just pressing the brake makes the light go on and stay on. i'm surprised tho that you guys dont notice how slow the car drives with the light on, i can tell the computer is really pulling timing. anyway, havent gotten around to replacing it yet as i'm currently in australia.
    Veteran Member Three Rings dextrek's Avatar
    Aug 26 2008
    B7 S4
    Detroit
    I experience the same issue...but only when it's cold outside. Anything to do with the temperature?
    -Ben-
    B7 S4 Dolphine Grey
    B6 A4 USP Moro Blue *Sold*
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    I remember this happening to the MkIV Jettas. Obviously no ESP light on those, but the brake light switch was a common failure.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    May 10 2008
    chicago
    hey guys
    my car is in the dealership being checked
    it is for some other issue, however since this ESP light problem happens to me, i asked them to check it too
    and they told me they could check it, but it would be $135 for a diagnosis, unless something is found wrong with it, then only the $50 deductible from warranty would apply
    since people in this thread mention that when dealer checks it at the shop it usually does not turn on, it only does so randomly when driving, and resets after you restart the engine
    should I tell them not to diagnose it? so i dont have to waste $135 dollars? but what if it is really a problem?
    HELP soon!! they are checking it on monday
    Veteran Member Three Rings 02B6's Avatar
    Nov 05 2007
    Toronto, Canada
    Whats involved in the faulty brake light switch? What is the part, and how is it do fix?
    What exactly does the switch do? I know on the tips, when the brake is pressed, the clicking sound from under the dash, but what about manual trans?
    2002 (B6) 1.8TQM...H&R - S4 Spoiler - 6k HID - open cone filter - Forge Splitter - avic d3 - podi/SW
    Established Member Two Rings afozzie40's Avatar
    Oct 21 2008
    B6 A4 1.8T
    Boulder, Colorado
    ^^same question manual trans
    03 B6 MT Sport suspension 15% Tint Custom Magnaflow exhaust K&N Stock Air Box Mod ECS Snub
    May 10 2008
    chicago
    Quote Originally Posted by spectzix View Post
    hey guys
    anyone??? bump
