Results 1 to 19 of 19
    Veteran Member Three Rings dewey527's Avatar
    Mar 10 2008
    '02 a4 1.8tq, '05 tahoe
    Puyallup
    stasis touring half way done...
    have the rears done and will do the fronts on saturday. dropping the subframe was the key! passenger side took way too long but the driver side was about 45 minutes. can't wait to see how it handles after taking off my blizzaks.
    mods - not enough for me and way too many in my wife's opinion
    K04, Revo "Stg2", PODI Boost Gauge, TT225, fmic, Forge DV, Tantrumwerks 300cell HFC, Neuspeed Exhaust, Stasis Touring Suspension, Spec Stg2 & LWFW, 034 RSB, Neuspeed SS, Neuspeed Snub, Neuspeed TIP, B6S4 front brakes, Tyrolsport Kit, 6K HID, Yellow Fogs, 20%, CC
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: stasis touring half way done...
    Quote Originally Posted by dewey527 View Post
    nice, make sure you have spring compressors and impact gun for the fronts
    - Clint
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Now if we could only get a thread like this about V-Maxxx coils.............
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    sweet Stasis was the way to go
    Mar 10 2008
    Puyallup
    ya it sucks to ratchet those spring compressors hopefully the fronts go a little more smoothly...and i think stasis rocks but i have to wait and see how the setup goes. i think it will be a great comprise for a daily driver.
    Veteran Member Four Rings A4A4A4's Avatar
    Jun 02 2008
    Victoria, Canada
    Can't wait to see the pics of the finished project.
    -Cam
    New: MK6 Volkswagen GTI
    Old: E92 BMW 335i
    Older: B7 Audi A4 2.0T Quattro
    Mar 10 2008
    Puyallup
    it won't look too good with the winter setup but in the spring it should be sick! have to setup an alignment and corner balance.
    Mar 27 2005
    The Cold North
    Please explain how you are going to corner balance a spring & damper setup? To corner balance you need adjustable ride height and adjustable sway links on this chasis.
    Here is a pic of the STaSIS Touring suspension.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    Please post pics of the ride height as soon as your finished!
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Mar 10 2008
    Puyallup
    i will look into it. i was informed i should be done to make the car feel and perform better. i've always stated i am not an expert. starting the front in a bit...just hope the movies hold over my daughter since that was a big time killer installing the rears...
    ps - when you hear a metal on metal sound when breaking, like i did, make sure your buddy puts the pad on the correct way. it was reversed and luckily on the inside
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by EBG 18T View Post
    you can still corner balance by adding weights where necessary
    - Clint
    Mar 10 2008
    Puyallup
    HELP... anyone know what direction the springs go on the front? more coils towards top or bottom?
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Hope you changed out the subframe bolts.
    They're one time use and should be replaced everytime they're removed.
    Those sure look just look like Vogtland springs and KONI shocks.
    Veteran Member Three Rings Kerschera4's Avatar
    Jun 21 2007
    DC
    wait a week or two to do your alignment for everything to settle properly
    and impact gun FTW when using the spring compressors
    Mar 10 2008
    Puyallup
    finally done...i will get some new subframe bolts to be on the safe side. process wasn't as bad as i thought it would be just that my 2 year daughter kept coming in and trying to take my tools...have some pics after i charge my camera battery of how it sits.
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Those pics are huuuuge!
    Veteran Member Four Rings italian a4 1032's Avatar
    Oct 17 2007
    mass
    how long did this take?
    Mar 10 2008
    Puyallup
    sorry about the pics... about 6 hours. could have cut an hour or so off for all the little stuff i had trouble with. both are pretty easy once you look at articles by capt obvious and a4mods.com
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    As long as the bolts will torque properly they'll be fine. I still run the original head bolts on my fully built motor, 100k and still rockin.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
