Results 1 to 8 of 8
    Registered Member Two Rings
    Nov 09 2007
    Philadelphia, PA
    3.0 coil packs the same as 1.8t?
    I've got 6 good coil packs from my 2003 3.0 and want to use them in my wife's 2003 1.8T. Are the coil packs the same between engines?
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    Re: 3.0 coil packs the same as 1.8t?
    I don't believe so. The 1.8T CPs have different part numbers than the 3.0 CPs.
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    check the part number on the coilpacks on the the 1.8t car and see if it matches the number you have on your new 3.0 coilpacks.
    May 28 2008
    2005 A4
    i have a 2005 1.8t and just replaced one of my coilpacks. The part number on mine is 06B 905 115 R (thats the new coilpacks part number. The original had an M at the end instead of the R).
    May 03 2005
    Boston
    The latest revision for the 1.8T is R. Just did a search...3.0 CPs are different than 1.8T CPs.
    http://forums.audiworld.com/a4gen2/msgs/1092509.phtml
    EPL S2 + TCU
    Previous Cars:
    Nov 09 2007
    Philadelphia, PA
    Thanks everyone for your input. I'm going to the dealer today to pick up some correct coil packs.
    Established Member Two Rings afozzie40's Avatar
    Oct 21 2008
    B6 A4 1.8T
    Boulder, Colorado
    i recently blew a coilpack and ran one of my brothers from his 3.0 for about a week with no probs except a CEL that went away when i got the new proper ones
    03 B6 MT Sport suspension 15% Tint Custom Magnaflow exhaust K&N Stock Air Box Mod ECS Snub
    May 28 2008
    2005 A4
    Quote Originally Posted by ind_dsnr View Post
    DONT GO TO THE DEALER! You can get 4 brand new one from ECS for just a bit over what youd pay for 2 at the dealer. Take a guess how I know.
