Results 1 to 31 of 31
    Senior Member Three Rings jaynyce's Avatar
    Nov 12 2005
    05 Audi A4 Quattro USP
    Fuel Filter began Hissing, why?
    Hello everyone, I bought my car with about 19K miles back in Feb. and had nothing wrong with it. Now I'm no Audi Expert but at that time the car was still a baby, 7k miles later I began to hear a strange hissing noise near the passenger rear wheel. I listened closer and realized that is was coming from the fuel filter. Now i have a habit of breaking things(lol), so i rather not touch it. Can anyone tell me whats the cause or what might happen if i don't fix it soon?( sorry for seeming like a dummy).
    Nov 28 2006
    2005 Audi A4, Yamaha gp800 Watercraft
    CT, USA
    Re: Fuel Filter began Hissing, why?
    i would fix it soon...it could be that your filter is simply clogged...this could put strain on the fuel pump...which can lead to pre mature wear and ultimate failure...hope this helps
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    First of all, you are not a dummy and there is no such thing as a stupid question. I once asked someone if I could ask them a stupid question, and their response was, "If you can think of one!"...lol.
    Anyway, your fuel filter just needs to be changed. It is getting clogged up with all the bad stuff it filters out and the hissing sound lets you know you need to change it. It's a really easy fix, just search for some DIY's, there's a ton of them. Really easy fix.
    If you don't fix it soon, it will place unnecessary strain on your fuel pump and eventually cause the pump to go out too. That's a $1,000 fix, so change the filter now and you'll be fine. Don't wait to long, it's hissing because it's full and it will make the pump go out. You can bet on that!
    Nov 28 2006
    CT, USA
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    I'll have to second what 04b6sport stated. Change your filter. It really isn't hard and there are several DIY's to help you out. Here is a little hint to add to the DIY. When you go to disconnect the lines to the filter try pushing the connectors TOWARD the filter body before depressing the release tabs. This will take the pressure off of the tab and make it easier to release. If it still doesn't release use the edge of a small screwdriver to press down on the tab.
    Good luck!
    Nov 12 2005
    Thanks everyone, Now for the Fuel Pump being replaced, I remember I had just got my 02 a few years back and didn't know much about Miltek's, neuspeed's, or apr's. so a friend who had a b5 told me he did his exhaust by Shea Stadium. I then followed and went to a local muffler shop and purchased 2 Obx mufflers and got them installed. while the guy was cutting the old pipe i didn't realize that he cut the gas tank. 2 weeks later i decided to full up my tank and started to smell gas when it got to the halfway point. i jacked it up and say the slit within the gas tank. i didn't even bother to go back because i know they would say they didn't do it and i didn't wanna deal with that crap. 8 months later the pump began to buzz while the car was idling. so it went and cost me about 700 to fix. I then changed the tank which was an arm and leg to replace. so i know better now, I went out and got the Resonated Miltek Catback, noproblems yet. lol
    Nov 12 2005
    Did I mention How much I Love you Guys? thank you all once again. I shall get to it tomorrow.
    Jun 21 2008
    Damn, talk about bad luck. That's bullshit to even think about a muffler shop sawzawing through someone's gas tank....wow!
    Nov 12 2005
    I know but I made a bad decision and had to learn the hard way, it pays to buy things that are already made to fit flush
    Jun 08 2008
    Calgary AB Canada
    i replaced my filter and it still hisses... whats up with that? pumps on its way out?
    Jun 21 2008
    Quote Originally Posted by onceover View Post
    You know what? I noticed the same thing.
    I replaced my filter and it still hisses, I've learned to live with it because I know the filter's good...
    Senior Member Two Rings Juggern@ut's Avatar
    Aug 10 2009
    80 Corolla
    Dirrty Jerzee
    When I changed my filter and the noise went away however 2 weeks later my pump went while i was on my way to work. Audi towed it for free but I think the charged around $900 to fix.
    it puts the lotion in the basket...
    Veteran Member Four Rings PDX04a4's Avatar
    Jun 22 2008
    2006 A4 Avant S-line
    SL,UT
    ya i changed my filter a while back and noticed a slight humming after i changed, but never really before. of course my roommate threw away the old filter before i could try putting back on to see if the humming went away. that was 4 months ago and i havent had any problems even though the slight humming is still there.
    Jun 21 2008
    To be completely honest, I've never heard of someone NOT having noise come from the fuel filter/pump.
    If anyone has no noise, post up...I'd like to know.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Absoltely zero noise
    040 drop in pump though.
    Senior Member Two Rings Peterjk4's Avatar
    Apr 18 2009
    B7 RS4
    NoVA
    No noise here, I just changed mine about 5k ago
    I also don't have the 4 connector type fuel filter, mine has two. And come to think of it, what are they other two connectors for?
    Current- No V.A.G.
    Gone, but not forgotten:
    03' Volvo V70 FWD
    02' C5 S6 Avant QA
    98' C5 A6 2.8 Avant QA
    01' B5 1.8T Avant QA
    96' B5 2.8 QM
    02' B6 3.0 QMS
    Jun 21 2008
    Quote Originally Posted by 400HPA4 View Post
    I stand corrected...thanks Greg. Good to know it's possible to have a silent setup..
    Senior Member Two Rings SilvA4Q's Avatar
    May 27 2009
    '17 Audi Q7 3.0T P+
    Houston, Texas
    Mine makes the humming/whining noise now also. Prior to changing the fuel filter the only noise was the slight charging sound, now its definitely more of a deep humming/whining noise. I checked the rail to see if there was a problem with the pump but it seems okay, just kind of odd that with a brand new filter it would start making noise, but with a filter FILLED with nasty particles, it sounded fine.
    Current:
    '14 S4 Premium Plus
    ll S Tronic ll Glacier White ll Bang & Olufsen ll Sports Differential ll Black Optics ll APR Stage 1 ll CR-15 ll H&R Front and Rear Sways ll AWE Touring Exhaust ll Afe Cold Air Intake ll
    Aug 10 2009
    80 Corolla
    Dirrty Jerzee
    Quote Originally Posted by SilvA4Q View Post
    Because the pump is now bad
    Veteran Member Four Rings lunamarA4's Avatar
    Feb 26 2004
    lots of tools and spare parts
    San Diego, CA
    Hi I just replaced my filter and its still hissing any ideas???
    4 SALE B6/B7 parts
    RafE |2004 BT White A4 Avant|
    |2002 S8 6spd - fully overhauled + 6 spd|
    |1988 E30 S52 Pandem Kit|
    |1991 E30 M20 Touring|
    Jun 21 2008
    Quote Originally Posted by lunamarA4 View Post
    Mine has hissed since day one...and I've been through 3 filters and a new pump. Have just learned to live with it.
    Established Member Two Rings joebleu's Avatar
    Dec 11 2009
    Los Angeles, CA
    Since we're on this subject... what's the best way to put the filter in with minimal amount of gas spilling out?
    Also, how do you clean it up afterward? Just wipe it with a rag? Do you just throw the old filter in the trash? I have never had to handle something as flammables as gas in my own garage before.
    I'm coming up on 70K and will be doing a lot of stuff. This will be one of them.
    Jun 22 2008
    SL,UT
    take your gas cap off to release some pressure.thats about it as far as preventing gas from spilling, i guess you could pressure the shrader valve on the fuel rail to release pressure from the motor side. not much comes out anyways. just wipe it up with a rag, you will be fine. you can throw the old filter in the trash. i put mine upside down in a cup to let as much ouch as gravity could take, i pushed some compressed air through it as well. let the gas evaporate a little out of it then toss it.
    Thanks for the EFF shack. -Dirty Mike and the Boyz
    Jun 21 2008
    Another good tip for the install is to swap one connector at a time over to the new one. You'll have two filters hanging there for a few minutes, but it will ensure you don't hook it up wrong...like so many others have. So go one connector at a time and you really cannot mess up the process.
    Established Member Two Rings Sublimize23's Avatar
    Nov 24 2009
    Chester County, PA
    I can hear what sounds like a hissing noise coming from the filter outside the car while it is running if I get close to the PS rear. Is that normal?
    Junior Member One Ring
    Dec 02 2009
    West Michigan
    Mine hisses/whines when it's cold outside. When it warms up past 40*F it's quiet.
    Feb 26 2004
    San Diego, CA
    Quote Originally Posted by Sublimize23 View Post
    that is what I'm talking about
    normally that is indicative of needing to replace it...but I just replaced it and its still doing it...and feels like it louder
    4 SALE B6/B7 parts
    Jun 21 2008
    Really? That's what this whole thread is about.
    If the filter is hissing, you need to change it (if it hasn't been changed in a while). If you don't change a clogged filter it will make the pump go bad.
    As I mentioned above, I've gone through a few filters and a new pump and mine still hisses...just something I've learned to live with.
    Feb 26 2004
    San Diego, CA
    thx Greg
    topic/crisis solved
    4 SALE B6/B7 parts
    Veteran Member Four Rings cruzin210's Avatar
    Dec 28 2005
    Former: B6 A4 1.8TQM
    Palo Alto
    As far as I can tell, loosening the gas cap before changing these things doesnt do a damn thing. I still get sprayed with gasoline everytime (done it a few times). My suggestion is to get a big plastic bag and cover your hands while you disconnect the lines. Yeah and I change mine every 10-15k or so and have had whining since the day I bought the car (bought at 15k, now at 65k). I just deal with it (cross my fingers) and do my due diligence on changing the filter every now and again.
    Black and Silver...thats it
    Quote By rds0000:
    "I actually prefer that this little t**l speaks this way, because in an otherwise anonymous environment, it really helps paint a nice picture of who is spewing this nonsense"
    Veteran Member Three Rings Dos::Avants's Avatar
    May 30 2007
    Garage no more :-(
    'sconsin
    Quote Originally Posted by jaynyce View Post
    Are you kidding me?!? I would have ripped them a new one if they tried to deny that shit! That's such a serious offense, ethically and safety wise, I don't know how they would have been able to deny it...WOW!
    Avanta-Humpa-Lot
