Results 1 to 8 of 8
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    Weird Problems cont.
    Well my electrical gremlins have not yet been solved. I'll give some info to get everyone up to speed on the problem. A few weeks ago while driving everytime I would accelerate my wiper blades would stop moving, I could not use my turn signals and my heating fans would turn off, the system stayed lit but no fans. Within 2-3 seconds of returning to a "cruising" position on the accelerator everything would return to normal. I checked fuses and the ecu box for water and did not find anything suspect. On a recent scan of the car I have kept on getting a code for missing steering wheel electronics. After talking with my mechanic he mentioned a ignition switch behind the key that could be causing my problems. Has anyone dealt with a similar issue?
    Some fast things and some slow things
    ~Josh~
    Account Terminated Two Rings
    Oct 09 2008
    moroblue 04 s4 6sp
    brooklyn
    Re: Weird Problems cont.
    sounds like a short to me
    Veteran Member Three Rings ziggituning's Avatar
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    Do a load test on the battery, some have had running issues when the voltage was too low, also I have seen the ignition cylinder on some cars develop problems when the owners would have too many keys hangging off the the key ring and putting strain on the mechanism, so long term it would be loose and when you accel the movement would jerk the keys and cause a cut or short. Also check the main power connections at the battery and at the fuse box, there are a few large red power cables under the dash on the drivers side, maybe one is lose and cuts power. The wipers and fans are not on the same circuit, but they are on the acc ignition line, meaning they only work if the car is on so see if any of the power leads are loose. good luck.
    PARTS FOR SALE: LW Crank Pulley, OEM injectors, ABT rep grill, OEM Intercooler, PM me.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM![/SIZE]
    Oct 31 2005
    Virginia
    thanks i'll have to check all of these
    ~Josh~
    Senior Member Three Rings B00sted20VUSP's Avatar
    Nov 11 2008
    Junk
    Chicago, IL
    Yes, ive see the ignition switch cause a similar issue, the contacts in the switch lose connection, car will not die but will cause wierd issues. For the record my brothers 01 A6 had a problem when he floored the accelerator the interior lights came on and the door open chime came on. Ended up being the comfort module under the drivers floor. Hope it helps. Good luck
    /S4 25 Quattro #139 | JHM 93 Oct Tune | Fast Intentions Non-Res Exhaust | Trexturk Downpipes | VMR Staggered Gunmetal 710's | RS4 Grille | RS4 Pedals
    Oct 31 2005
    Virginia
    Is there any way I can check to see if the ignition switch is bad, i was told to to wiggle the key while the problem is occuring and that will make the problem go away, if this is true i tried this and it did not work. Does anyone have a diagram/picture of the wires that could be suspect in this problem, of the electrical system I'd like to go thru and look to see if anything is loose and i'd like to know where it comes from and where it goes
    ~Josh~
    Established Member Two Rings smarrick's Avatar
    Apr 07 2008
    04 A4 18T 6MT QT SPORT, 07 X3, 74 Lincoln Continental
    Fort Collins, CO
    Quote Originally Posted by moroblues4 View Post
    Ya I would go with there is a short somewhere that is bringing that circuit or circuits down. When you get on the throttle may cause the short to occur since motor and things shift postions a little.
    Fort Collins Drinking Team Member #2
    Senior Member Three Rings 03 silverbullet's Avatar
    Dec 05 2008
    1.8 Q 05 GSXR 03 CBR RR
    Quote Originally Posted by mtbrider View Post
    u cant wiggle the key the ignition tumbler is held in with a 4 mm bolt, there is a DIY write up on replacing the ignition switch.
    If u take off the bottom of the steering column u will b able to at least get at the black wire harness that plugs into the ignition switch
    here is the link http://www.audizine.com/forum/showth...gnition+switch
    i just replaced mine because i was having problems with the car starting the first try, i wasnt having any other problems that you have said you are having
