Results 1 to 23 of 23
    Dec 06 2008
    07 Audi S4
    Is this Possile? Swirl Marks?
    Hi Guys and Gals, I just got my B7 S4 a few months ago.
    After the first snow fall, I brushed the snow off my car.
    It appears that my snow brush has left straight lines of "swirl marks" from brushing off the snow.
    Now I think that they may of been there before and I never noticed. But I looked over my car many times before it snowed and NEVER noticed them.
    Do y'all think thats possible? My snow brush is a normal brush with nylon/plastic bristles.
    I may be just plain crazy but has anyone else experienced this?
    Account Terminated Four Rings
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    Re: Is this Possile? Swirl Marks?
    sounds really weird. My car has never been snowbrushed, so I can't say it has happened to me (garaged at home and work)
    what colour is yours? Wonder if I've seen you before. I've got a silver 2007 with the RS4 looking wheels for summer and the stock 2007 wheels for winter.
    Quote Originally Posted by sagexl View Post
    Dec 06 2008
    07 Audi S4
    Re: Is this Possible? Swirl Marks?
    I have a Black one....I know the marks always show up more on a black car but...........dang......
    I tried to find a bristle-less snow brush...and found:
    http://cozywinters.com/shop/sno-brum.html
    http://www.rateitall.com/i-1811051-a...now-brush.aspx
    Mar 01 2004
    2004 Audi S4, 1997 Audi A4 1.8
    Northern NJ
    I dont know about those snow brooms, any debris on the car is going to be dragged across the paint. And when it packs while dragging, it will only press into the paint harder. Id say do a complete wax again the spring, compound the paint down, clay bar, etc do it right. The light scratches are usually very easy to get out. If you cant feel it with your nail, then you can usually get it out. If you use good wax, the light scratches will only be in the wax. and when you do it again in the fall/winter, they will come out.
    Active Member One Ring tafc1383's Avatar
    Nov 09 2008
    ct
    the only problem with those snow brooms are if your car is not perfectly clean which is almost impossible if its snowing in your area, it will drag the dirt and salt across the paint leaving behind very apparent scratches. no good IMO
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    Quote Originally Posted by tafc1383 View Post
    yep that is why i try to avoid it all cost
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    Dec 06 2008
    07 Audi S4
    Thanks for tips, but what should I used instead?
    No Bristled snow brushes, No Snow brooms.....
    Also, what course of action should I take in waxing my car to get out the light scratch marks?
    Thanks!!!
    Account Terminated Two Rings
    Oct 09 2008
    moroblue 04 s4 6sp
    brooklyn
    yep when it snows don't take the snow off the car it will come off on it's own
    you can bush your windows off no problem just dont touch the paint because
    your paint isn't clean it will put lines in your paint happed to me also
    when i went to clean off my car it was really dirty and i didn't see it left lines in my paint i just waxed it and it worked but when the wax comes off you see again you have to compound the car to get off the lines but if you keep up with waxing the paint you woun't see it
    Mar 01 2004
    Northern NJ
    you cant leave it on your car in NJ, you can get a ticket for it if its excessive. You shouldnt anyway, pretty scary when a huge chunk flies off the car ahead of you. Usually Ill hit the windows good, and get most of it off the paint, but leave a 2in layer. This way bristles dont touch, and itll blow off probably.
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    Quote Originally Posted by Audi0s View Post
    pretty much the same here i have ice thrown at me on the highway not fun
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    yes, those brushes can leave light marks. try the Sno Brum, i use it on all my cars.
    Dec 06 2008
    07 Audi S4
    Hmmm...at this point I think I may try the sno brum and start looking for a good wax or compound to use in the spring.
    Any suggestions on what brand of wax or compound works best for AZ members?
    Veteran Member Four Rings 2PUTT's Avatar
    Nov 09 2005
    UBIQUITOUS
    it will buff out. you will need paint correction in the spring. it is the worst for black cars. good luck.
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Veteran Member Three Rings Kerschera4's Avatar
    Jun 21 2007
    DC
    i would recommend this 100 times. i use it a few times a year and it takes out all surface scratches and swirl marks. my b5 was black and now my b6 is ming blue and this works very well on dark cars
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    Quote Originally Posted by 2PUTT View Post
    tell me about it
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    Jun 02 2008
    sweet silver goodness...
    Nov 09 2005
    UBIQUITOUS
    Quote Originally Posted by Kerschera4 View Post
    major skip. mostly filler. visit the detailing forum to learn more about proper paint correction. fillers basically hide the swirls. they do not reduce/eliminate them.
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Mar 01 2004
    Northern NJ
    I 2nd skipping meguires, use high quality stuff, i use p21s system, check out detailersdomain.com they can help alot. Also phil from DD is on audiworld alot, you can try contacting him to help.
    Aug 16 2004
    SE PA
    check out detailers domain. thay have plenty of good products. i like 1Z and Klasse. Also research the detailing forums here, detailing world, autogeek, and autopia. you'll find tons of good info.
    Apr 16 2007
    New Jersey
    yes, you will learn a lot from the detailing forums. detailersdomain.com is your friend. it took me a while before i saw the light but my paint has not been in this good of shape since the car was new. things get pricey but overal very well worth it
    also, get a snow brush that uses boars hair. a little pricey but much more paint friendly
    Jan 01 2008
    Long Island NY
    menzerna ftw
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    dark colors show swirl marks like crazy...even sprint blue. Black is even worse...
    You'll have to use some semi-abrasive polish to get those out. I'd say to have a professional get you setup...but then, you may want to do this once the season is over....
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
    Veteran Member Four Rings Fade2Black's Avatar
    Nov 27 2008
    Black B6 S4
    Springfield NJ
    No big deal to fix.
    Either pay about $150 to have some one buff it out or spend about $250 and buy the product and tools to do it yourself.
    Bst investment I've made for my cars.
