Results 1 to 3 of 3
    Veteran Member Three Rings nihil's Avatar
    Oct 01 2007
    Too small
    N/A
    `04 USP front fit an `02?
    Based on the searches I did it looks like it'll fit (upper and lower bumper/inserts), just wanted to confirm.
    2002 A4 1.8TQMS (sold)
    1982 MB Geländewagen 300GD
    1968 Charger R/T
    1987 Porsche 944 (sold)
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Veteran Member Four Rings sambrody44's Avatar
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Re: `04 USP front fit an `02?
    I believe you need a different rebar, other then that, direct swap.
    "set your mindstate free"
    2002 Audi A4 1.8TQM
    Lowered by Stasis SS (finally) On 19" ADR M-Classics.
    Bailey's DV
    Neuspeed Short Shift
    Southbend FE SS Clutch with AWE Flywheel (13lbs lighter then stock)
    Buy my photos here.
    Mar 22 2008
    Lancaster, PA
    Rebar is the same for the front, no need to change. If you do the rear, you'll need the Euro rebar or do like many of us have done and just modify it to bring it 1" closer to the body so that the rear USP cover will fit. There is a DIY on here for it and it's easy.
