Results 1 to 9 of 9
    Established Member Two Rings ivoryman50's Avatar
    Oct 20 2008
    2006 GSX-R 750, 1998 GSX-R 750 SRAD
    Ormond Beach, FL
    swap s4 xenons to my a4
    i have an 02 a4 and my roommate has an 04 s4. he just got bi xenons and i wanted to know what i would have to do to retrofit his stock single xenons into my a4. thanks in advance for any help.
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Re: swap s4 xenons to my a4
    be a good roomate and you'll get them for free.
    But seriously, Nothing. Just remove two top screws on the radiator mount, and losen the bottom 2 screws on the headlight tray. They don't need to be removed, just loosened.
    Then slide the headlight out, use a flathead to unlock the wire harness clip, and then swap.
    You're done
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Sep 13 2008
    Western Chicago Burbs
    i belive the top ones need to be removed completely
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    Quote Originally Posted by A4 Moda View Post
    You're done
    this is true if the headlight is complete (bulbs, ballasts...) if NOT, then it is slightly more involved. there are a few writeups on here somewhere.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Oct 20 2008
    Ormond Beach, FL
    the headlights are not complete. i will be using the bulbs and ballasts from my a4 single xenons which are not the slim ballasts that the s4 uses. would that be possible to do?
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    Quote Originally Posted by ivoryman50 View Post
    yep, just a simple plug and play. enjoy the new look!
    May 22 2007
    oakland ca
    not necessarily, this is what i had to do when changing to s4 bi-xenons from stock xenon:
    •new high beam bulbs.
    •modify the 'door' the ballast fits into. it's a 5 min job if you have a dremel. took me 15 with a drill and a hacksaw. and a bit of silicon as a "just in case"
    •move a wire to a different pin on a cluster plug.
    maybe different on s4 single xenon, ,but this is what i had to do. nothing was a big deal, but not 'plug and play'
    Aug 16 2004
    SE PA
    Quote Originally Posted by cjonesgo View Post
    he's not upgrading to bi-xenon's...
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    His single xenons should go right it to your car, I think you might have to VAG a setting for them though.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
