Results 1 to 4 of 4
    Veteran Member Three Rings SummitS4's Avatar
    Sep 19 2006
    2001 audi s4
    Los Gatos
    damn belt keeps popping off!!!
    so the other day is driving on the freeway and i lost power steering. i found that my accessory belt came off. i got the car to my friends house and replaced it. then it came off. i just replaced the tensioner and it fell off again. i checked the pulleys and nothing seemed to be loose or over tight. i need help!!!!!!!
    2001 nogaro s4 2.8 tial 770's........... 1972 Audi 100ls Bagged
    530 awhp 540 awtq on 91
    Sprint Auto Works / Becausebags
    Rotiform/Airlift
    Sep 19 2006
    2001 audi s4
    Los Gatos
    Re: damn belt keeps popping off!!!
    bump??
    Rotiform/Airlift
    Veteran Member Four Rings PinoyS4's Avatar
    2018 catalunya RS3
    sf bay area
    make sure all your pullies are all aligned and tight cause if 1 is just slightly off, it will slowly slide the belt off
    work hard, play hard[;)
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by PinoyS4 View Post
    Yeah, I threw my belt because the pump pulley had lost 1 bolt and two remaining ones were loose...
    08 S4- Stock SOLD
