    Veteran Member Four Rings LimiTed's Avatar
    Oct 13 2006
    Bay Area
    How to get brake dust off?
    So as much as i try to clean my rims with soap and water, there's brake dust that seems almost caked on that i cant get rid of. im scared to use any other type of cleanser because the clearcoat is already peeling on one of my rims. what other solution do i have? is there any cleaners that for sure won't harm the finish? thanks
    btw, they are iForged rims with a brushed alum finish if that makes any difference.
    Mar 27 2005
    The Cold North
    Re: How to get brake dust off?
    you could try a clay bar and see if that helps.
    if not you should had cleaned them more often.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Senior Member Three Rings blackbox619's Avatar
    Oct 24 2008
    nyc
    try a high pressure hose, some gas stations have them for their self service car washes and it removes a ton of build up.
    ~~ engineered in germany... modified in brooklyn ~~
    Veteran Member Four Rings Stone825's Avatar
    Dec 02 2008
    nowhere
    Simple Green worked for mine in getting everything off when I was prepping them to paint.
    Audi A6 2.7T : 6MT : 88K Miles : GIAC Chip : 2.5" Catback : Hotchkis F+R Sways : AWE DTS
    Established Member Two Rings king505's Avatar
    Jan 13 2009
    2005.5 B7 A4 2.0T Q TIP
    I used to use brake cleaner, would not recommend. Use Audi Wheel cleaner smells like soap works great, break dust comes off no problem. This is the link "http://www.audipartssuperstore.com/catalog/product_info.php?cPath=310_314&products_id=1087" or go to any Audi dealership, they should have it.
