I did a rear brake job a while ago and when I finished up and went for a drive, the rear, passenger side brake would "grab" when I would brake. It was as if it wasn't running true or it had low and high spots on the rotor. Well, I checked the runout on the rotor and measured a difference of over 0.007" on the rotor. I didn't think it could be the rotor since it was brand new, so I took it off and checked the hub. The hub had runout of about 0.004" on the outer edge and it was very gradual going from 0.000" to 0.004" on the runout indicator.
So ever since then I've been driving on it and finally today I decided to take it all apart again. While I did this I tried playing with the hub to see if it was sitting in tight... It wasn't. Whenever I move the hub up and down, it will actually move a bit but if I move it left and right, it won't. I even rotated it and it still did it the same way. I then went over to the rear, driver-side and raised it up and took the wheel off and the hub didn't move at all, so that led me to think something is wrong.
Would this mean something is damaged in my wheel bearing or wheel bearing housing? How would I go about checking this?
