I have a 98.5 30v qm myself. Also black on black :). I replaced the clutch with a southbend stage 2. It's kevlar and grabs a bit more than stock and I like it.
I also changed my timing belt without the locking bar. Got the JHM kit with the DVD and it went very smooth. If you make good marks, it's no problem. Also replaced water pump, thermostat, coolant temp sensor and accessory tensioner.
Also, I had to change the valve cover gaskets as they were leaking and the cam chain tensioner gaskets. Seems like they seem to go on everyone's 30v. My valve cover pcv tubing was also super brittle and snapped so I replaced with silicone and put an inline catch can. There was some oil in the throttle body, so I wanted to keep it clean after all that work cleaning it out.
Recently I went for a drive and one of my rear wheel bearings is making noise, so lol, I'm on a roll!!!
Oh yeah and check out your oil cooler while you're under the car. It's the rounded square box that you screw the oil filter to. It basically has coolant going through one part and oil in the other so if it starts leaking, it needs to be replaced.
Soon though, I will have it back to 100% shape.
