Results 1 to 9 of 9
    Veteran Member Three Rings MrScary512's Avatar
    Dec 31 2008
    St. Paul,MN
    Interior Question
    Well I just covered my headliner with "burberry" like fabric. I'm wanting to do the same thing to the trim strips on the doors and dash. But I would like to keep a glossy look, so it still looks kinda stock. I've had a couple suggestions for it, from vinyl to fabric with clear epoxy resin. Well I'm wondering if anyone has done this, and if you have do you have pictures.
    Thanks
    Veteran Member Four Rings sambrody44's Avatar
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Re: Interior Question
    I don't think anyone on here has done that, while maintaining a gloss finish. I think you should wrap it and then spray resin it. Keep in mind, you will need quite a few coats.
    "set your mindstate free"
    2002 Audi A4 1.8TQM
    Lowered by Stasis SS (finally) On 19" ADR M-Classics.
    Bailey's DV
    Neuspeed Short Shift
    Southbend FE SS Clutch with AWE Flywheel (13lbs lighter then stock)
    Buy my photos here.
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Oh yeah and you will have to build up a nice thick layer of resin then sand, getting progressively finer as you go, eventually wet sanding and polishing.
    2002 Audi A4 1.8TQM
    Bailey's DV
    Buy my photos here.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    I'm sure a bar top clear lacquer would work, or have them clear coated.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Dec 06 2007
    Pics NOW!
    -Kirk
    BetaAlphaTau Member #58
    Dec 31 2008
    St. Paul,MN
    Thanks for the options. I'll look into em once I have some more cash to throw around
    Senior Member Three Rings auggy's Avatar
    May 15 2008
    Washington, DC
    pictures of the headliner?
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Quote Originally Posted by MrScary512 View Post
    Thanks
    can we get a pic?
    Dec 31 2008
    St. Paul,MN
    Yea I'll get one soon. I don't have one right now tho.
