Results 1 to 16 of 16
    Oct 31 2005
    Ashburn
    What kind of exhaust is this
    My friend has a cat-back exhaust from an audi at his shop so i told him to email me parts numbers so i could post it and maybe someone could tell me what model audi it came off of.
    One thing he did say was, there are some kinda of valves on the rear muffler portion of the exhaust.
    I also wanted to see if i could gain any interest in the part.
    Here's a pic of the part number he sent me.
    - Instagram: @Sinister_rs5-
    Veteran Member Four Rings Grishbok's Avatar
    Apr 15 2008
    Reston
    Re: What kind of exhaust is this
    looks like its for type 8E, B7 chassis... but that valve is throwin me off and i can't make out the rest of the part #
    2008 A4 Quattro Brilliant Black
    *SOLD*
    StreetTunedTV.com
    You are violating the 3 rules of forum posting.
    1. Title thread appropriately
    2. Use the search first
    3. If you didnt find what you were looking for, its because someone else didnt follow #1.
    Senior Member Two Rings DEB5S4's Avatar
    Jun 21 2008
    Stamford, CT
    Could be for a RS4 which has the sport button, hence the valves.
    Oct 31 2005
    Ashburn
    ^^That's what i was thinking, sadly i have more responses with less views in this section than i do in the B6/B7 s4/RS4 forums.
    Jan 10 2007
    VA
    i was under the impression that both the B6/B7 S4 and RS4 contain valved exhaust. Just like the R32. For open throttle and high rpm driving the valves open to allow better flow, but when crusing they close for quiet ride.
    Veteran Member Three Rings MisanoRS4's Avatar
    Sep 15 2008
    Northern VA
    Looks like an rs4 muffler to me. The last picture is a little dark so i cant make out the whole thing, but from looking at just the muffler it looks like mine.
    2010 GT3- Sharkwerks muffler bypass
    "The reason my car has 4 rings is because my gf has 0" -ngng
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Quote Originally Posted by b6onboost View Post
    neat!
    Veteran Member Four Rings FastB7S4's Avatar
    Mar 01 2008
    12 CC Lux Ltd, 11 Touareg, Mk3.5 Cabrio
    ChesCo, Lancaster, PA
    Looks like my b7 exhaust. How many tips?
    /S4
    AWE l Koni l H&R l Hotchkis l VMR l LEDs by fly
    Veteran Member Three Rings KarimS3's Avatar
    Aug 12 2007
    2011 S4 S-tronic
    Washington DC
    B7 S4 exhaust doesn't have valves on the mufflers. This is definitely an exhaust off an RS4.
    Apr 15 2008
    Reston
    that exhaust just got sexier.
    *SOLD*
    StreetTunedTV.com
    Mar 01 2008
    Quote Originally Posted by KarimS3 View Post
    Hate to tell you but mine does. I noticed it when I swapped out to my AWE. It's sitting in my shed right now and looks just like the picture with the vacuum hose and everything.
    /S4
    Oct 31 2005
    Ashburn
    I was thinking it was an B6 S4 because it has single tips, the B7 S4 has dual tips plus the fact there round tips and not oval like the RS4. But still not sure that's why i put that hard to read part number there.
    Mar 01 2008
    If it has single round tips than it is most likely from a B6 S4. Dual oval tips than it could be from any of the current S line-up (S4, S6, S8) since they all have similar looking exhausts. There is no mistaking the large single oval tips of the RS4. If you look into the oval tip of the RS4 exhaust, you'll see 2 outlet pipes from the muffler.
    /S4
    Oct 31 2005
    Ashburn
    This exhaust does have 2 outlet pipes coming from the muffler.
    Mar 01 2008
    B6 S4. You should've posted that pic in your first post and it would have ended the discussion. When I said 2 outlets for the RS4, I meant 2 straight outlets with a single large oval tip covering both pipes. The B7 S4 also has 2 straight outlets with a tip for each pipe (hence the quad tip). The pic above has 2 outlets merging into one with a tip (B7 S4/RS4 pipes don't merge).
    /S4
    Sep 15 2008
    Northern VA
    Yeah def. not my car, the mufflers do look similar though
