Results 1 to 7 of 7
    Oct 19 2008
    South Florida
    Epc, Esp, And Cel
    Ok, so the last couple of day's my car's idle was a little erratic, rpm's were jumping from 900 to 1100, sometimes even to 1200 or 1300. This morning i start the car and my EPC and ESP lights are on, I turned the car off and waited about 30 seconds and turned it back on and now the CEL is on, so i have all 3 lights lit up. I drove the car around the block to see if I could drive it, I had absolutely no boost, my boost gauge read 5lbs and didnt get any higher. Any1 know what the issue might be?
    Veteran Member Four Rings Grishbok's Avatar
    Apr 15 2008
    Reston
    Re: Epc, Esp, And Cel
    gonna have to read the codes man. If you dont have a vag-com you can borrow the obd2 reader from autozone for free, or take it to dealer. welcome to limp.
    2008 A4 Quattro Brilliant Black
    *SOLD*
    StreetTunedTV.com
    You are violating the 3 rules of forum posting.
    1. Title thread appropriately
    2. Use the search first
    3. If you didnt find what you were looking for, its because someone else didnt follow #1.
    Veteran Member Three Rings CX-7&A4's Avatar
    Dec 09 2007
    CX-7 AWD/A4
    Foreclosure Captial of the US
    Make sure you have $150+taxes when you go there for a deposit, but yeah read the codes first.
    07 Mazda CX-7 AWD
    06 Audi A4 Fail2Trak CVT - TRW Front/Mintex Redbox Rear
    Oct 19 2008
    South Florida
    ill check the codes, but im defiantly going to the dealer. No1 know's what it could be?
    Oct 19 2008
    South Florida
    Quote Originally Posted by CX-7&A4 View Post
    Deposit for what?
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    Sounds like you need to have your PCV valve replaced.
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Oct 19 2008
    South Florida
    I'm hoping that its an easy fix like pcv replacement.
