Results 1 to 3 of 3
    Veteran Member Three Rings djez016's Avatar
    Sep 01 2008
    04 toureg /94 sliverado /98 e320
    Delaware
    Oil leak strange????
    Ok so my audi has been down and out for most this month 1st fuel pump now the icm so it has just been sitting. Today while outside I noticed 3 oil spots under my car there is one in the middle, then one on each side of the car. The 2 side ones seem to coming from some hoses under the car while the center one i have no idea where its coming from, but my main concern are the hoses on each side of the car as they seem to have the bigger leaks more so the one on the passenger side.... does anyone know what these hoses are???? oh and i have 2.7 could they be the oil lines for the turbos ????? i have pics but im having problems uploading
    passenger
    .....GAVE YOUR GIRL 4 RINGS NOW SHE AUDI.....
    http://www.cardomain.com/ride/3083923
    Apr 18 2007
    ny
    Re: Oil leak strange????
    Bro, first off please use commas and periods, it is very difficult reading your paragraph without them.
    About 2 months ago Audi changed my rear main seal (thank god for CPO), but I was having the same problem over and over again and they would keep changing the prop shaft seal (which was fine by the way). By the the fourth time this happened I demanded they find the problem, and they did after adding some dye to the oil and finding the rear main seal to be the problem. I would also check cam seals, they are known to leak.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Sep 01 2008
    Delaware
    Quote Originally Posted by A62TURBO View Post
    sorry about that my laptop key board like half ass works so some buttons work some don't like( t . , e r) i have to hit them a few times to work so for he most part I try to type what I have to.
    but ill look into the seals
