Results 1 to 11 of 11
    Forum Moderator Four Rings
    Apr 16 2005
    Pearl City, Hawaii
    Headlight bulb replacement..
    Passenger side bulb went out.
    I want to get a brighter/white(r) light output.
    Which bulb should I go with?
    B5S4/A3S3RS3/Hawaii Forum Moderator - PM Comments/Concerns
    18 Daytona Gray Pearl S3
    00 Laser Red S4 (Sold )
    VAST Performance | BLOUCH | AWE | EvolutionRacewerks | Volk Racing | Vogtland | STaSIS/Alcon | JHM Motorsports | RS4 OEM
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Re: Headlight bulb replacement..
    Power Bulbs in UK delivers FAST!
    Get the Vision Plus H7: mondo!
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by Jesse S. View Post
    well since you have stock ballasts you have to get a D2S bulb... Go to ECS tuning, I had great luck with the ZiZa bulbs, they aren't as expensive either and come in a pair. They were a bit brighter by eye.
    http://www.ecstuning.com/stage/edpd/...egory=Lighting
    Veteran Member Four Rings Silverstreak98's Avatar
    Dec 11 2006
    Minnesota
    Brightest are going to be Philips or Osram 4300k bulbs. These are OEM bulbs and will put out the most lumens for a 35w HID setup.
    As they age the Philips bulbs will turn more blue/white, while the Osrams will turn a little pink/white.
    ~Brian
    1998.5 A4 2.8QT
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    I just get my bubls on eBay. If you find "Autobahn" bulbs, they should be around $40. I've been running a pair (6000k) for over 2 years with no problems.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Apr 16 2005
    Pearl City, Hawaii
    Thanks for the replies.
    I might go with ECS since I see they have the city light kit for sale.
    Which bulbs did you purchase? 4500k? 6000k?
    Aug 06 2008
    Canadia
    I got GE nighthawk H7's and they are nice, but quite pricey. A cheap alternative is some Hella 80W H7 replacements, no fancy coloring, just higher wattage, usually available for about $12 (here anyway) each. compare that at around $40-$50 for a set of bulbs with a color coating, i think its a good deal. just keep an eye on your harness, the chance of it melting becomes very real with higher wattage bulbs.
    the B5 S4 is like the mafia... there is only one way out!
    Veteran Member Three Rings 2ndEngineS4's Avatar
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    4500K is going to give you the best visibility with a yelowish tint, similar to the factory bulbs. For safety and function, this is your best bet.
    6000K is going to give you a little bling (bluish tint similar to OEM Acura HID's) but usable light output is decreased. I personally had a difficult time seeing the lines on the highway when the road was wet with 6000K bulbs, other than that, they were okay.
    JHM.Vast.034.ER.SR.AWE.RS4.Apikol.APR.Innovate.Stg III
    Registered Member Two Rings i5wikcedi3's Avatar
    Oct 05 2008
    2001 Audi S4 Stage 2+
    San Diego
    Ebay... 6000k HID bulbs 30 bucks shipped a pair. Save yourself 100 bucks?
    "Fear No EVO"
    GIAC Chip, AWE DP's w/ hiflow cats, AWE Twin 2 system, AWE DTS, AWE Boost Gauge, APR Bi pipe, EVO intake, 710N DV's, STaSIS T/S Suspension, Short Shifter, Euro headlights, RS4 clutch kit, 11 lb Fidanza flywheel, PowerStop D/S Rotors
    Oct 05 2008
    San Diego
    Ebay also have 5000K d2s bulbs by Philips for around 60 shipped. Very well worth looking into. Save a bunch of money.
    "Fear No EVO"
    Jan 16 2008
    '15 S5, slippahs
    Home
    Hey Jesse, you gotta let 'em know that you need HID bulbs and not H7. Get some PIAA's, they're only like $500. Hehe!? Seriously though, wasn't there another thread with a dealer selling some good bulbs for us? Forgot where tho.
