Results 1 to 40 of 71
    Veteran Member Four Rings veggiemonster's Avatar
    Oct 20 2008
    fuck off
    k04's under warranty?
    okay so i have a 2002 s4 6 spd.
    ive been running on a giac 93 chip for over 10k miles and i am pretty sure i just spun the bearing on my pass. side turbo . i have a GE warranty that covers just about anything (covered cv boots a month ago and a cam seal)
    my questions are:
    1.)has anyone who has/had a 3rd party warranty ever gotten k04's through the warranty?
    2.) If i manage to find a shop willing to do this what are the bare essentials i need to run k04's?
    my friends sti is sponsored for the most part by AMS (the real one in chicago) as a prototype/production car and he can get my a tune session for about 250 dollars.
    i already have a jhm stg1 clutch and LW flywheel and new mounts (motor, trans, snub) ready to go in, i also have a saamco tbb
    i know i will need new DV's and the inlet hoses but what is an absolute must?
    thanks guys,
    Sean
    Mar 26 2007
    2001 S4, 1999.5 A4
    Chambersburg
    Re: k04's under warranty?
    My aftermarket warranty company agreed to pay for factory replacement turbos (K03), so I just paid the difference to get K04's. You need the inlets, but different DV's are not a requirement. The car will run on your current fueling, but you won't get the full benefit of the the larger turbos. So, to answer your question, the only absolutely, necessary additional thing you need for K04's is the turbos themselves and the inlet pipe kit. If you do this and want a deal on an AWE Stage 3 fueling kit, I am thinking of selling mine...
    Veteran Member Three Rings dak360rt's Avatar
    Apr 17 2008
    Sacramento, Ca
    my shop told me the same thing, that they have gotten warranty companies to pay for K03s and then you can pay the difference for K04s
    Im just curious what is the difference that you would pay between the K03 and K04???
    Light Silver Metallic - 2001.5 S4 - APR Stage 2+
    Piggy Pipes --- CC Mod --- Darintake --- Samco TBB
    AWE Boost Gauge --- 1 touch rear windows up
    JHM Weighted Shift Knob --- JHM Solid Short Throw Shifter --- Custom Straight Pipes
    Oct 29 2005
    10speed
    San Francisco, CA
    they wont know how to tune your car at said "tune session"
    - Clint
    Veteran Member Three Rings laxman851's Avatar
    Jan 09 2008
    2001 S4
    NC
    Whats up with the AMS comment? Did you have a bad experience with AMS tuning?
    Senior Member Three Rings AddICTioN's Avatar
    Dec 06 2007
    Houston, TX
    Curious what the price diff is as well...
    Widebody B5 S4
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    get a quote from the dealership on k03 replacements...I bet it is around 4000-5000 due to the 30+ hours of labor. Now go to an independent audi shop and get a quote on k04s and inlets. I bet the k04 will be cheaper, if not the same. obviously this doesn't include fueling or a tune but you can add that later.
    Apr 17 2008
    Sacramento, Ca
    i hope the parts price wont be that different
    OEM K03s from dealership (rape and pillage pricing)
    vs
    K04s from a tuner (competitive pricing)
    Or do warranty companies require dealership sourced parts?
    Veteran Member Three Rings TheDarkness's Avatar
    Jul 13 2008
    15' A3 2.0T , b5 S4 Stage III
    I'm planning on doing this too if/when my k03s blow, wondering how much the difference would be too
    2001 Stage III Pearl White B5 S4: Frankenturbo F21s | Iforged Flux | Solo Motorsports Dyno Tune | Bosch EV14 52#
    2015 A3 2.0T 8V Mythos Black: KW V3s
    Mar 26 2007
    2001 S4, 1999.5 A4
    Chambersburg
    My dealer quoted $3800 approx. for K03 replacement. K04's cost has gone up recently, but I think that K03's are somewhere around $1700 for a new set, and the K04's $2200-$2300, so $500-600 more for the turbos, and $350-$600 for the inlet pipe set, depending on what kind you get, so maybe $850-$1,200 would be a ballpark estimate. It is well worth it, once you get fueling, exhaust, etc....
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by joules View Post
    A pair of new K03's is gonna set you back about 2600 dollars. 1300 and change for each one. K04's are currently at what, 2500 a set? You still need inlets, but I think the choice is obvious.
    08 S4- Stock SOLD
    Mar 26 2007
    2001 S4, 1999.5 A4
    Chambersburg
    Quote Originally Posted by dak360rt View Post
    Warranty companies don't require dealership sourced parts--the cheaper the better, as far as they are concerned, but they may require the shop to guarantee the repairs, so that the warranty company doesn't have to pay to fix the same thing at a later date.
    Oct 20 2008
    fuck off
    Quote Originally Posted by laxman851 View Post
    no the main reason i made that comment is because i will most likely get a tune for half price essentially.
    and i am confident in the capacity of chris the tuner there to tune it. chris is the one that tunes the shop evo and every single customer car. he's tuned their diesel van, ls1 corvettes, and of course the cars they advertise specialties in.
    there are a few people there that have worked at i think rennart? i know its start with an R. but they know s4's pretty well, and i really do not want to drive my car, in vacuum, the at least 3 hours to vast when i can drive 10 miles instead.
    one more question though,
    what type of boost levels are safe on stock fueling, and depending on price of this endeavor, keeping stock downpipes?
    thanks a lot for the help guys!
    --Sean
    Active Member Two Rings SonicS4's Avatar
    Jul 10 2008
    MN
    Big turbo 4-banger = totally different ballpark than a biturbo v6. Can he tune it? Probably. Get it running at max capacity? Most likely not. Why not just search around and find someone selling a Stage 3- tune.
    Stock downpipes can be kept, but gonan be a huge performance downer. Gut the pre-cats. Vast can do it, another reason you should just go there :P
    Oct 20 2008
    fuck off
    yes because i need my stock fueling downpipe intercooler s4 maxed out with k04's on it only. that sounds smart.and if the can make 500 whp per litre i think they can tune fine
    Jan 09 2008
    2001 S4
    NC
    Quote Originally Posted by sdoherty_tjm View Post
    That would be AMS performance that you would be getting the discount from... not AMS tuning.
    Good luck with the swap, the discount will come in handy... let us know what fuel kit you go with.
    Jul 06 2005
    "Tuning" the car is the easy part. Understanding the ECU and getting definitions for the hundreds of maps within ME7 is the hard part.
    If he hasn't tuned multiple ME7 cars before, I wouldn't expect good results. I doubt he even has the tools to do it.
    FYI, you can slap K04's on your car and it will run perfectly safe at WOT, you don't need to drive it in vacuum. You just won't be making more power than K03's until you upgrade the fueling and software.
    I'd go to VAST, but good luck with whatever you decide. You don't need to drive to Michigan to get it, he uses UPS.
    Don't put stock DP's back on either, at least piggyfy them.
    Slow, stock, smurfy blue car.
    Relax, I just troll this place for fun.
    Oct 20 2008
    fuck off
    Quote Originally Posted by Shomegrown View Post
    so you're saying that a k03 giac 93 will use the same wastegate duty cycle? i find that hard to believe.
    when i talked to them there they said if they dont have the program just make sure you have it yourself and thats pretty much all they need.
    im not looking for the most performance just something that runs safely for cheap. if vast can do it for less then i'll just talk to them.
    right now i have 2200$ to use and thats if i spend literally zero dollars through this month which wont happen lol
    May 16 2008
    South Texas
    Make sure your warranty co will replace both turbos not just the defective one. BTDT
    Oct 20 2008
    fuck off
    i had my car in for an oil pan, cv boots, and rear cam seal at laurel audi and an adjuster came out and he said they will not replace the turbos till they blow, they were only making a "little" noise, but that once they do they will cover it.
    I'm sure they dont want to fork out a motor pull twice thats $$$$$$$$$
    Established Member Two Rings kodycobra's Avatar
    Jul 15 2008
    00S4,07 ZX14,05 AcuraTL,Z32tt
    Jefferson City, Missouri
    sdoherty tjm Where can one find out about the warranty service company you have?? Thank you!!
    http://i94.photobucket.com/albums/l9...000_0009-1.jpg
    00 Nogaro~Two little GT28rs's on a mission
    Oct 20 2008
    fuck off
    Quote Originally Posted by kodycobra View Post
    uh i can tell you that its is a GE (general electric) third party warranty. i will try and find out some more stuff about it and post back here
    Jul 15 2008
    I found it, thank you. That's all I needed to know.
    Oct 20 2008
    fuck off
    okay here is the brochure for what i have. i have the 4 star program i know for sure and if i remember i do not think i could get te 4 star plus program because the car was used.
    when i bought my car with exactly 60k miles, it cost 2800 dollars. i have already saved 1900 on repairs and have yet to do the turbos.
    http://www.geaws.com/autowarranty/b2...amBrochure.pdf
    and this is the main site. it is pretty barren though:
    http://www.geaws.com/b2b/publicjsp/our_products.jsp
    Jul 15 2008
    Thanks again man! Be sure to keep us updated on how the turbo replacement goes
    Oct 20 2008
    fuck off
    yep will do. next week im gonna live on my phone calling different shops and getting quotes and such. it gonna suck
    Jul 06 2005
    That's the whole point, the software won't run the same wastegate duty cycle. It will run less with K04's.
    That's why you have a MAP sensor. If you install K04's and do nothing else, the car will run less wastegate duty cycle to try to follow the same boost curve as you had with K03's.
    Oh, that makes it easy then.
    The program you need to tune ME7 costs a couple thousand dollars.
    You can buy it here, but only if you have your own tuning company.
    Then you need the DAMOS files, because otherwise you'll have no idea what the maps are doing. You can't buy that.
    Then you need the flashing equipment or chipwriter. Count on a few thousand more.
    If they haven't done an ME7 car before, you're not going to get a tune from them. End of story.
    Oct 20 2008
    fuck off
    well what about lemmiwinks or whatever that is?
    Jul 06 2005
    That's like trying to service the space shuttle with vice grip pliers.
    Lemmiwinks will tweak a tune. It's not tuning a car, and it's usefulness is very limited.
    It's not capable of doing anything useful to a stock tune or a K03 GIAC tune that will help you with your setup.
    Oct 20 2008
    fuck off
    okay thanks. so maybe ill just talk to vast. the only thing is i cant fork out 500+ for something ill change as soon as i can with fueling and such. but if i can use the giac 93 i'll hold off i guess
    Dec 15 2004
    Chicago
    where do you live in st. charles, il? my parents live there and i live in north aurora.
    i would recommend taking the car to Chicago Performance and Tuning (www.gocpt.com). they will do a much better job on anything that needs to be done on the car including any type of LEGIT/PROPER tuning.
    they also deal with aftermarket warranties quite well.
    2001 Stage 3 S4
    Jul 06 2005
    If you feel confident enough to play with the setup yourself, do some searchs (you'll need to go to AudiWorld, this place is usless for anything technical) on "homebrew" or "Stage 3-" setups. There are things you can do yourself to get the most out of your setup. In the old days, we used to put a Zener diode (aka TCD) on the MAP sensor and run a manual boost controller in parallel. Then you can run slightly more boost than a K03 setup on the K03 software. You'll need some sort of logging software (minimum VAG-com, ideally ECUx) to get the most out of that configuration.
    Talk to VAST and tell them you can't afford to shell out much, and see what they'll do.
    Oct 20 2008
    fuck off
    i live around the wasco area. its campton hills or some shit now. like rt. 64-47 --ish.
    do you know alex? yellrs4 on here? he has a yellow s4 lives right off randall/indian trail.
    wait is this jim or steve?
    Oct 20 2008
    fuck off
    okay thank you very much. i've so far gotten a lot more info out of this than i originally thought i would
    Dec 15 2004
    Chicago
    Shomegrown is giving you some good advice too. again, i would seek some assistant at shops that do lots of work on B5 S4s.
    CPT and VAST are definitely 2 of them. no idea what you are going to get out the AMS route.
    if you need anything locally, let me know. good luck! btw - i know steve who has the imola.
    2001 Stage 3 S4
    Oct 08 2008
    MA
    Talk to VAST. I know they update tunes for free so maybe you can work something out with them if you buy a stage 3- file right now.
    Oct 20 2008
    fuck off
    Quote Originally Posted by djillusion View Post
    yeah i met him hes nice. has the wide body a4, well has a stg 3 s4 engine now.
    he sold a trans to my good friend alex. and jim has a noggy stg 3 hes probably a mile or so away from where steve lives.
    we should get a small meet going when it gets nice out
    Oct 20 2008
    fuck off
    having looking at their website im def. going to call them. their tune prices are ridiculously cheap.
    have you personally dealt with them?
    Dec 15 2004
    Chicago
    yes. many of us S4 chicago-land owners get work done at CPT. since they are local to many of us, they provide awesome service and work. al is the owner. so when you call speak to him or his brother paul. im very confident you will be happy with their work.
    they did lots of work on my stage 3. from suspension, fueling, custom ASP tuning, alignments, etc. they do it all...top notch.
    2001 Stage 3 S4
    Oct 20 2008
    fuck off
    and they have had no problem being a performance shop and doing 3rd party warranty work? thats great.
    thank you very much i had never even heard of them before
    edit: what is their labor rate? do yo know off hand?
