Results 1 to 9 of 9
    Jul 12 2008
    audi b6 avant
    Fredericton NB Canada
    need tiptronic picture please
    i send myc ar to a local garage and the added a aditive for my trany but i'm realy sure they added it in the TC ...
    it it possible for you guys to post picture that show where to fill the automatic trany, and the front diff
    they added the fluit in a drain plug just before the drive shaft (or close to) absolutly not in the black trany oil pan.
    my car is a 2003 avant 1.8T automatic.
    thank a lot !
    NO, I'm not drunk or stupid. i'm from Canada and my first langage is FRENCH, so don't ask why my english suck so hard !!!!!
    Established Member Two Rings Plasticar's Avatar
    Jul 08 2008
    B6 A4Avant, B5.5 Passat 4mot
    West Bloomfield, MI
    Re: need tiptronic picture please
    I don't know for sure, but I thought our transmissions were sealed. I am sure someone will correct me.
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    nope, not sealed, they just tell you that the fluid is "life time". it's good to change it though.
    don't have any photos of the tranny, sorry.
    Veteran Member Three Rings ziggituning's Avatar
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    To my knowledge, to fill the tranny, you need to have the car lifted, and running, you also need to have the car plugged to a vag com and at a temp of about 37 deg., thne you open the plug located on the underside of the tranny near or at the tranny oil pan. There are some other spots you can open here and there. I think the tranny and front drive and TC all use the same oil, but I may be wrong.There is also a myth that if you havenot changed the oil and filter in the auto trans by a certain milage, then you should not touch it, but I am not too sure how much I beleive in the old story. Good luck
    PARTS FOR SALE: LW Crank Pulley, OEM injectors, ABT rep grill, OEM Intercooler, PM me.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM![/SIZE]
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    I've seen trannys go bad shortly after changing the filter and fluid. But this was on older domestic cars.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jul 12 2008
    audi b6 avant
    Quote Originally Posted by ziggituning View Post
    someone can confirm this please ?
    if it right, i'm good to go !
    thank a lot guys for your input !
    and, happy new years !
    Established Member Two Rings 377Z's Avatar
    Aug 25 2008
    Chicago, IL
    It appears that the trans fluid, front differential, and center differential are all separate in the tip cars. See page 4, 8, & 9:
    http://www.zf.com/na/content/media/i...g/5HP19FLA.pdf
    I've been searching around to see what besides the $OEM$ fluids will work, since this ZF manual only specs stuff I'm not familiar with (Burmah SAF AG4, Sturaco FM 1992 ???).
    No luck so far.
    2007 Volvo S60R
    2005 A4 2.0T Quattro
    1998 Ford Explorer Sport 4X4
    Jan 28 2007
    dallas TX
    the tranny isnt sealed at all.. not sure if u need the 6 point star... i just did mine when i redid ma motor but i used redline d-4 atf and it works soooo much smoother... make sure u do the filter too helps wonders !! also heard others using royal purple and mobil one atf too...
    Aug 25 2008
    Chicago, IL
    Yeah, the fluild flush is pretty easy, I just used one of those hand pumps that screws into a quart bottle.
    I used Amsoil ATF. Didn't notice a huge change in performance, but the car only has 53K.
    2007 Volvo S60R
