Results 1 to 10 of 10
    Established Member Two Rings cjnesher's Avatar
    Oct 31 2008
    DG 05 A4 2.0T 07 Passat 2.0T
    Tampa, FL
    Low fuel Light won't turn off!
    Last night I Vagged my car for the first time. Did the auto windows and the seat-belt chime. Everything works perfect windows with remote and the annoying chime is gone! When I started the car this morning the low fuel symbol popped up on the display. This was odd because I have half a tank of fuel. I also noticed on the display computer 1 does not show the distance any longer.
    I went in to the display and distance is checked on computer 1 it's just not showing.
    I did notice if I uncheck it on computer 1 it also is then unchecked on 2 and vice versa.
    Has anyone had this issue after running the vag?
    Veteran Member Three Rings Elohite's Avatar
    Jan 14 2008
    San Antonio, TX
    Re: Low fuel Light won't turn off!
    If your car FWD?
    Garage Inc | APR | Britalman | 034| Stasis | Volk |Rotora | Deval | EuroGear | DTH | Thule | Forge | BSH | AWE | Evoms | H&R | Pioneer | JL Audio | TMA | ZiZa | KLight
    Oct 31 2008
    Tampa, FL
    yes
    Veteran Member Three Rings sdjeff's Avatar
    Jun 04 2008
    B7 A4 2.0t, Dino 246 GT
    RSF san diego
    I ran into the same problem.. it was the seatbelt chime code that was a few numbers off. I entered the code that was posted for the Seatbelt Chime (0023259) instead of calculating what it should be. My original code was 0022261 and not the 0023261 that was in the screenshot. When I corrected it the fuel display issue went away.
    Jan 14 2008
    San Antonio, TX
    When I did these two mods + more on vagcom I had the same problem
    I was frustrated bc nobody on here knew so I took it to the dealership
    I somehow changed something to make the car think it was quattro instead of fwd
    They changed whatever code and it was fixed and i still had my vagcom changes working
    If you cant figure it out i suggest going to a dealership.
    Oct 31 2008
    Tampa, FL
    Makes sense! So what do I minus from my original code?
    Jun 04 2008
    RSF san diego
    Quote Originally Posted by cjnesher View Post
    Change the 3 for a 2. Your code right now is probably 0023259 and should be changed to 0022259.
    Oct 31 2008
    Tampa, FL
    Sweet!! I'll let you know. FYI I lived in OB for 12 years... FL is cool but you can beat SD.
    Oct 31 2008
    Tampa, FL
    Thanks for your help SDJEFF... Worked perfect!!
    Jun 04 2008
    RSF san diego
    Glad to help!
