Results 1 to 7 of 7
    Veteran Member Four Rings jamestown478's Avatar
    Dec 24 2008
    2000 S4 stage 2+ on meth
    Milwaukee
    got my brakes done
    so I had new rotors and pads put on my car and when I got it back from the shop my abs light now stays on and the brake light blinks. wtf did they do to my car?
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Re: got my brakes done
    They might not of cycled the ABS module.
    Are you sure it's the ABS light and not the brake pad wear sensor? If they replaced your front pads with pads that don't have sensors, it would stay on permanently unless you short it out.
    Dec 24 2008
    Milwaukee
    what do you mean cycle the abs module? I am almost positive its the abs light and not the pad wear sensor cause its yellow and says "abs" and how would I be able to check if the pads they put on have the said sensors you are talking about? where would they be located?
    Senior Member Three Rings Johnnada's Avatar
    Aug 02 2008
    04 Audi A4 3.0, 09 BMW 328 X-Drive
    MA
    Did you choose the pads yourself?
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    Quote Originally Posted by jamestown478 View Post
    Look to see if the sensor is hooked into the calliper.
    Look at picture 13 and 14 here
    Sep 19 2008
    Toronto, Canada
    Cycling the ABS Module with VAG-COM:
    http://www.ross-tech.com/vag-com/cars/absbleeding.html
    The sensors are in the front pads only, on the inner side. It should be pretty obvious if there is a connector there that is not plugged in to anything.
    Good luck.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Make sure they topped it off with brake fluid. Low fluid can cause the light.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
