Results 1 to 17 of 17
    May 09 2007
    jersey
    does any one know
    does any one know where this "Barometric Pressure Sensor is". This senser seems to be a BIG problem for the vw/ audi community. I think its somewhere around the intake manifold. thanks for the help.
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    Re: does any one know
    i would guess the map sensor. i dont think theres a sensor specifically called barometric pressure sensor. the map measures pressure so that would be it. its on 2000+ and its located on the smic. not really an big problem. havent heard of them going bad
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    May 09 2007
    jersey
    Quote Originally Posted by zrowcool View Post
    well i installed a front mount and for some reason iam in limp mode, i cleared the code be i dont go away at all. its just stays there. iam just trying 2 figure out witch sensor is bad.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    What year model is your car? I think I have received this code before, and it was due to the fact that an intercooler hose had popped off or was REALLY loose. Id check on that man.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    May 09 2007
    jersey
    2001 awm
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by spre23 View Post
    2001 awm
    When you did your FMIC, did you make sure that you put back/incorporate the MAP sensor back into the setup?
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    i cant remember what year, but after a certain point, the A4 stock side intercoolers had some sensor plug into the side mount.
    1989 Nissan 300ZX
    Lemons Race Car
    1999 Porsche 911 Carrera
    1-Off Widebody | LS1 Swap | AST 5200 2-way Remote Coilovers | blah blah blah
    2000 Mercedes Benz C230K
    The Daily | "VIP Build"
    2000 Audi A4 1.8T
    The New Track Build
    2006 Porsche 911 Carrera S
    LN Engineering 3.8L | H&R Suspension | IPD Intake
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by geeky View Post
    I don't believe this was on the B5. Seeing that that picture came from A4mods.com its probably a B6.
    My 5-Speed Swap DIY
    - B6 USP
    May 09 2007
    jersey
    yea i didnt connect that. i kinda thought it was useless.
    Jun 04 2007
    Austin/DFW, TX
    LOL, massive
    You HAVE to have that.
    My 5-Speed Swap DIY
    - B6 USP
    Nov 09 2006
    Bronx, NY
    necessary for your car. the 2000 and 2001 had that MAP sensor which is exactly what a barometric pressure sensor is. it senses pressure to apply the right amount of fuel. You have to install that on your FMIC. get a mount welded on and then install and your limp mode should would go away after clearing
    2000 A4 1.8tq
    Nov 02 2008
    Boulder & Seattle
    wait was i right? im so confused haha :p
    1989 Nissan 300ZX
    Lemons Race Car
    2000 Audi A4 1.8T
    The New Track Build
    Jun 04 2007
    Austin/DFW, TX
    Well the thing is that on the B5, the sensor was connected on a seperate pipe and wasnt attatched to the SMIC. But he just forgot the sensor all together.
    My 5-Speed Swap DIY
    - B6 USP
    Nov 02 2008
    Boulder & Seattle
    haha thats a moment of
    1989 Nissan 300ZX
    Lemons Race Car
    2000 Audi A4 1.8T
    The New Track Build
    Nov 09 2006
    Bronx, NY
    its attached on the smic on the 2000 ATW. right on top. I'll snap a pic if needed
    2000 A4 1.8tq
    Feb 27 2005
    North Wales, PA
    MAP sensor = Manifold absolute pressure sensor
    Barometric sensor senses the cars current atmospheric conditions to make adjustments for the altitude and barometric pressures. This sensor is located next the ECU in the ECU box.
    May 09 2007
    jersey
    Quote Originally Posted by poopie View Post
    map Sensor = Manifold Absolute Pressure Sensor
    Barometric Sensor Senses The Cars Current Atmospheric Conditions To Make Adjustments For The Altitude And Barometric Pressures. This Sensor Is Located Next The Ecu In The Ecu Box.
    Does Any One One Have Pic Of This Connect To Their Front Mount? Bc My Front Mount Is Custom
