Results 1 to 14 of 14
    Senior Member Three Rings eurotecknik's Avatar
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    URGENT!!! Faulty Code 16395 HELP PLS
    I have a code if anyone can help
    Wednesday,31,December,2008,00:35:13:18724
    VCDS Version: Release 805.1
    Address 01: Engine
    Control Module Part Number: 4B0 UNI 018 BT
    Component and/or Version: 1.8L R4/415 G 0001
    Software Coding: 16201
    Work Shop Code: WSC 12338
    1 Faults Found:
    16395 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
    P0011 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    From Ross Tech on WIKI:
    16395/P0011/000017 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
    Possible Symptoms
    Power Loss
    Possible Causes
    Camshaft Adjustment Valve 1 (N205) faulty
    Fuel Pump Relay (J17) faulty
    Possible Solutions
    Check Camshaft Adjustment Valve 1 (N205)
    Check Fuel Pump Relay (J17)
    Special Notes
    When found in Engine: 4.0l W8
    Check TPL 2010059(RoW)
    Check/Replace Oil Sieve in Timing Case (Camshaft Adjuster)
    I don't know where to start HELP PLS!
    01 A4 1.8T Quattro Manual - SOLD
    90 Audi 90 Quattro Manual - SOLD
    03 A4 1.8T Quattro Manual - SOLD
    B5 S4 Daily Driver - SOLD
    Current:
    06 A4 Quattro Auto
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    Re: Faulty Code 16395 HELP PLS
    No one has experience with this?????? Come on, I used search nothing shows on the topic. ANYONE???:"???
    Current:
    06 A4 Quattro Auto
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    bump it up
    Current:
    06 A4 Quattro Auto
    Veteran Member Four Rings Lazer Viking's Avatar
    Nov 06 2006
    garage ornaments
    southeastern pa
    Re: URGENT!!! Faulty Code 16395 HELP PLS
    calm down
    looks to me like your cam position sensor took a shit
    the code p0011 is not in my book
    p0010 however is "-a- camshaft pos. actuator circ. bank 1 malfunction"
    do you have any symptoms ?
    -Nic
    My Car
    old junk new junk, red junk blue junk
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    You went full retard
    {99.5 Avant}
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    Quote Originally Posted by pacman View Post
    calm down
    Nah. Drives the same to me. No check engine light. I don't know
    Current:
    06 A4 Quattro Auto
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    So if I replace the sensor, how hard is it to get to? open up the cover for the tb and than what? Pic anyone? Is it on towards the top or bottom?
    Current:
    06 A4 Quattro Auto
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    Quote Originally Posted by Jibberific View Post
    you never go full retard.
    but seriously, if you want schematics that will show you exactly where every nut and bolt goes, check out vagcat.com
    yes you have to register, but its basicly a free online version of ETKA. did i mention its free?
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    heres a link: same fault, cam tensioner replaced. really good diy write-up.
    have you recently had your timing belt replaced, if so, it may be a tooth off. one tooth wont make it "A splode" but it does set faults for cam positioning.
    the cam positioning sensor is to the right of the cam pully, attached to the head and block by 2 10mm bolts. it has a 3 pin black connector. take off the upper timing belt cover, and remove the 2 bolts. look at the sensor to make sure the 13mm bolt is still tight, and the sensor ring and pickup are not damaged. also, while you are in there, inspect your timing belt for any damage if it has not yet been replaced. if all is good, you will need to check your camshaft tensioner assembly next. this is located under the valve cover. get to tdc as indicated on the cam gear. check the marks on the crank pulley at this time as well. make sure both line up, otherwise your timing is off. remove valve cover (have a spare gasket ready) and look at the markings on the tensioner assembly. the 2 arrows need to line up with the 2 squares, and 16 rollers between the two.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    Quote Originally Posted by B5A4Kevin View Post
    Thanks Kevin. I should have mentioned that tb was replaced 9K ago by an audi shop.
    Current:
    06 A4 Quattro Auto
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    Should the battery be disconnected first? Removing the sensor will not throw the car in service mode will it? Sorry I haven't done tb that's why I dont know. I know about turbo since I did that myself
    Current:
    06 A4 Quattro Auto
    Feb 12 2006
    09 A4 Avant, 07 A4 Avant, 98 Jetta TDI
    Charlotte, NC
    THe fault doesn't have anything to do with your timing belt, that would be a different fault for cam/crank position allocation, you have a problem with the cam tensioner at the back of the cylinder head under the valve cover. You either have insufficient oil pressure to the tensioner or the tensioner itself is bad.
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    Is it safe to drive it, till I get it fixed? I have noticed that 1-2 months ago the you could hear very low-pitched rattling anytime the car war running nothing major. I thought that is normal after BT. I believe it is the cam chain tensioner now
    BTW the cam position sensor seems ok.
    Current:
    06 A4 Quattro Auto
    Apr 06 2008
    Brandon, FL
    Quote Originally Posted by aarononymous View Post
    that is why i included the link for the tensioner diy r&r. yes it is a different fault if your engine is slightly out of time, but it will still cause a cam position fault. i just stated the part about the timing belt and sensor inspection to eliminate them as possible causes, as it takes less effort to remove the front cover rather than removing the valve cover and inspecting the tensioner.
    as aarononymous states, it can very well be caused by insufficient oil pressure to the tensioner, as 1.8t's are notorious for sludged oil pickup screens, which will burn up a motor. if you do replace the tensioner, be sure to inspect your camshaft bearing caps for any signs of excessive wear or pitting. this is a sign of the engine overheating due to insufficient oil supply caused by sludge. if your oil pressure light comes on, and you have bearing damage, and your vehicle falls into the specified criteria (8years, unlimited mileage, maintenance receipts), AoA will replace your complete engine and turbocharger under warranty. if there is no bearing damage they will do a chemical desludge service and replace your oil pickup tube/screen.
    edit: overlooked the part about being bt. so this means in your case AoA wont replace your engine and turbo, but then again, im sure you dont wanna go back to k03 anyway. it is safe to drive for the most part, but i would consider doing a desludge service in the near future. this may alleviate the valvetrain/lifter noise as well as possibly fixing your tensioner issue.
    Current whip:
    RIP:
