Results 1 to 13 of 13
Thread: Tip Tranny
    Active Member Four Rings 00s4slvr's Avatar
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Tip Tranny
    i have the same problem... http://www.audizine.com/forum/showthread.php?t=254728
    any idea on what it could be?
    Veteran Member Three Rings Justin:NorCal's Avatar
    Feb 08 2008
    2000 Audi S4 (new build), 2000 Audi S4 Stage 3 (stolen last year)
    Dublin, CA
    Re: Tip Tranny
    The OEM TCU is designed to work with certain torque ranges in certain gears. Also, you could possibly have a seal in the TC that has gone faulty in which case you will need to replace the TC. About $800 + labor. Your e-clutch packs could also be toast. There are several things that can come into play.
    Sep 20 2007
    Harrisburg, PA
    Re: Tip Tranny
    x2 ^^ Agreed. The extra power and the heavier weight definitely puts more strain on the Tranny. I wouldn't recommend to go WOT anymore if you burn your 4-5 clutch pack you'll need to rebuild it and at that point you might as well rebuild the full trans. I may have a TC and tip chip for sale shortly if you're interested pm me.
    Senior Member Two Rings SeattleS4's Avatar
    Aug 08 2007
    Re: Tip Tranny
    Quote Originally Posted by 00s4slvr View Post
    Are you still running the stock TCU?
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: Tip Tranny
    Quote Originally Posted by johnkent1212 View Post
    yes i am still running the stock tcu. it doesnt make sense because when i switch the chip back in stock mode it works completely fine...
    any suggestions??
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Re: Tip Tranny
    my stg 3 tip in drive will kinda hunt around, but in tip she is fine, my E cluch from 4 to 5 and 5 to 4 is getting a lil tired i noticed latly I am taken it easy on the car in that gear untill i get the founds for a spare trans( or buy a 6 speed car and start a new project I wish lol ) for a total build out to swap out. I run a 2bennet TQ and it is mint, have you looked for codes in your car? some times you get them with out a CEL. My software in my trans is GIAC with the recode done as well to hold first gear and it works well, untill noticed the E cluch issue starting I had no hunting issues , hope this help, any ? PM me
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: Tip Tranny
    hey thanks that was a lot of help.
    i vaged the car and i got no codes... i dont get it. It only happens in tip just at like around 140 which is almost red line for 4th gear, it will get stuck and upshift and downshift from 4-5 and 5-4 unless i ease up on the throttle then it will shift and i can push down and continue going. (this only happens in pump mode, on stock its fine)
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    Re: Tip Tranny
    Gear hunting. Tranny cant keep up with the power. Happens to all of us.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Jun 24 2008
    Re: Tip Tranny
    Quote Originally Posted by S4 in_lowplaces View Post
    Do flashed TCUs help to solve the issue, or is it a lost cause?
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    Re: Tip Tranny
    Quote Originally Posted by GunSupplier View Post
    I'm pretty sure yes. Tcu also calculate engine load. It may takes bad calculations after stage3 especially after replacing MAF housing.
    I would speak with Jason at JHMotorsport, they surely have something for you if you have a 2000 or 2001 tcu.
    you'll have to waite if you have a 2002 tcu.
    Feb 09 2008
    imola b5 s4
    minneapolis
    Re: Tip Tranny
    not to me...fully built tranny.
    Feb 09 2008
    imola b5 s4
    minneapolis
    Re: Tip Tranny
    i
    this sounds really weird, but I had the same problem, and it was the torque converter being stuck off. It was not locking up properly. I started doing some research and found it can have to do with the MAF if you don't have any codes. I replaced my MAF and it solved the problem for a little while until my TC and trans completely failed. But then I was able to get a fully built trans and TC and have not had any problems since.
    Feb 09 2006
    Huntington Beach
    Re: Tip Tranny
    Quote Originally Posted by gunchs4 View Post
    how long have you been running this trans? Did they replace the clutch packs on all gears? Did you get valve body done as well? Last question. Are you running any type of TCU software? If not, you might be able to squeeze even more out of the trans.
