Well I checked worldimpex. They offer the same solution:
For my car with my vin number it pointed to model APB so that says I need part number 8 which is the three parts - valve, piping and check valve and make your own replacement part. Stupid if you ask me. Note pic below.
Soooo I did a search, (I should of did it first of all) and found this post:
http://www.audizine.com/forum/showth...e+booster+hose
The guy in that post had his brake booster hose blow apart by the check valve and he found one from this site:
http://www.independenttuning.ca/ that place is in Canada so I sent an email to see if they have the part. I'll update if I find anything out. seams a lot of people are having this same problem with getting this stupid brake booster fixed.
On simular note I am getting these codes:
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 35-10 - - - Intermittent
16826 - EVAP Emission Control Sys: Small Leak
P0442 - 35-10 - - - Intermittent
This is one reason why I'm thinking I need to replace my brake booster, plus because it has a small leak from check valve when I pressure test car. I did try a temp fix by using jbweld on the check valve on outside to see if that helps, but it seams to not make a difference. I havnt tried doing leak test since then, so I will try that maybe in a few days.
Anyway I found another post where someone says :
"for the EVAP faults. Bet ya 20 bucks the purge valve is failing. To this day 99 out of 100 small and intermittant leak faults I've seen have been cured with new purge valves. Actually most all EVAP faults are due to faulty purge valves. Over time, the mechanical portion of the valve goes bad causing various faults."
Is the purge valve the same as the check valve in the brake booster?
The entire reason I want this fixed is 2 reasons - I have a small boost leak somewhere which obviously is not good, but secondly when I go into full boost in 5th or 6th gear (17-18 psi) I get a maf max pressure CEL code
They say this is because of boost leak so I think with these codes together if I can fix this bost leak with the brake booster hose - purge valve (what ever that is
) then all my problems will be solved
....... Until the next one occurs.
Again if anyone knows a place that sells a replacement brake booster hose with out having to make your own, please post. Thanks
