Results 1 to 10 of 10
Thread: Turbo Timer
    Oct 21 2008
    2003 Audi A4 1.8t
    Dallas
    Turbo Timer
    Whats a good turbo timer for a b6 1.8t.... And easy to install?
    Senior Member Three Rings a4mafia(Red)'s Avatar
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Re: Turbo Timer
    whats your deffinition of easy?
    ...i like turbo timers, but many many ppl on here will tell you they are unecessary.....i'd go full automatic
    work in progress....
    B5 A4 2.8 FWD Transmission:
    http://www.audizine.com/classifieds/...ct=9554&cat=12
    Established Member Two Rings Nor-Cal'N's Avatar
    Dec 14 2008
    SLC, UT
    Re: Turbo Timer
    Quote Originally Posted by a4mafia(Red) View Post
    ...i like turbo timers, but many many ppl on here will tell you they are unecessary.....i'd go full automatic, something along the lines of this...
    http://http://forums.audiworld.com/a.../2263846.phtml
    Enough said. Dont waste your money; you only need a "cool down" period if you have gotten into heavy boost or have had a long drive then you can just sit in your car in the parking lot and leave it on for around a minute to be safe.
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Re: Turbo Timer
    Turbo timers are a waste of money. Modern oils (especially the synthetics you should be using in your Audi) don't sludge like the oils of yesteryear.
    If you drive you car nicely for the last minute or so and change your oil every 5-7k miles with quality oil, you have nothing to worry about.
    -Darrick
    Sep 04 2008
    p
    Re: Turbo Timer
    you wont be able to lock the doors with the controller until the car is off.
    my 2 cents
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Re: Turbo Timer
    Quote Originally Posted by msr1 View Post
    my 2 cents
    not true..you can wire it so it will....i havent done it, but i've seen ppl who have
    Veteran Member Three Rings GarbatyA4's Avatar
    Aug 10 2007
    Ontario Canada
    Re: Turbo Timer
    Yah, its called Turbo Timer Companion Lite
    I run an APEXi Turbo Timer, It's aight. Tells you voltage which is decent.
    I have it set for 1 min. If i ran the car hard, I gently drive home and let it time for 3 min
    2012 Audi Q5 - Daily (slow AF)
    2013 Mini Cooper S - sold
    2005 BMW 325Ci - sold
    2007 BMW 335i - sold
    2004 VW Golf TDI - sold
    2004 Audi S4 V8 Cabriolet - sold
    2003 Audi A4 1.8T - GT2871R - sold
    2000 GMC Sonoma - sold
    1992 Dodge Stealth RT - sold
    1991 Chevrolet Beretta GTZ - sold
    Mar 16 2009
    2019 Honda Accord Sport
    Hanford/CA
    Re: Turbo Timer
    Can any of you guys that Have Turbo timers installed post pics? Im thinking of getting one, after reading this thread I might not unless I upgrade the Turbo. A min in my car after a long drive wont hurt me.
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Re: Turbo Timer
    I have a Clifford 2 way alarm, as well as a Greddy turbo timer.
    They have worked flawlessly for the past 4 years.
    I would suggest you get an aftermarket security system that has a built-in turbo timer.
    Also note that because of our ECU Programming, it would be much much easier to use a Can-Bus adapter/converter to help you wire in the alarm system. Otherwise, a 30-45 minute job turns into a 4-5 hour job because of wiring hunting.
    Ask me how i know.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Veteran Member Four Rings Wet0willy01's Avatar
    Nov 17 2008
    05 A4 USP, 00 S4, 01 A4, 16 A3
    Re: Turbo Timer
    Quote Originally Posted by Kenjuro View Post
    New style HKS type 0. Sorry for the shotty pic (video still shot) but it was the only one I had on my PC this morning.
    -Andrew
    2005 Dolphin Grey Ultra Sport
    630AWHP HTA3582R 1.8L 93+ Meth
    Before camber and tire stretch, there was horsepower and performance.
